Thread: Evap system Vaccuum line setup
Results 1 to 9 of 9
  1. #1 Evap system Vaccuum line setup
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Hey i took my car to a mechanic shop yesterday and the mechanic told me that one of the vaccuum lines shouldn't go to the transmission. Can yall tell me what is the right setup im taking pictures of the current set up now.
    Sent from my SM-N920T using Tapatalk
  2. #2 Re: Evap system Vaccuum line setup
    Sep 2014
    New Orleans
  3. #3 Re: Evap system Vaccuum line setup
  4. #4 Re: Evap system Vaccuum line setup
    Quincy, Mass
    97 uses the 4t60e trans which requires vacuum. 98+ uses the 4t65e which does not use vacuum
    No more GP 04 Impala SS Indy:
  5. #5 Re: Evap system Vaccuum line setup
    Sep 2014
    New Orleans
    Where is the evap canister on the 97 grand Prix i dont see where to hook the vacuum line to and should i just cap off the vacuum slot on the trans?
  6. #6 Re: Evap system Vaccuum line setup
    you need the vac line to the tranny its what makes it shift.
    evap line runs to the fire wall and down around the master cylinder. TB to evap solenoid, then its out line is the one to the fire wall, it goes back to the gas tank fuller neck. where the canister is.
  7. #7 Re: Evap system Vaccuum line setup
    fWIW..the way your lines are run, appears to be all hosed up. Looks like your evap soleniod is going to trans.
  8. #8 Re: Evap system Vaccuum line setup
    Sep 2014
    New Orleans
    The trans supposed to go to the Tb or evap solenoid
  9. #9 Re: Evap system Vaccuum line setup
    Quincy, Mass
    Evap should be connected to tb, trans T's to the line on the fuel pressure regulator
  1. how do i delete the evap system?
    By Alexgp in forum Introductions/Noob Questions
    Last Post: 06-10-2016, 07:39 AM
  2. Evap System
    By Flip97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2014, 06:34 AM
  3. Evap system leak in '06 GXP
    By GPGXP06 in forum 5.3L V8 (LS4)
    Last Post: 06-13-2012, 10:30 AM
  4. WTB: Stock L67 Injectors and blower vaccuum line elbow
    By ill12will8 in forum Wanted To Buy - Parts
    Last Post: 02-09-2012, 10:49 PM
  5. EVAP Line...
    By black98gt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2009, 04:28 PM
