Thread: L36 Misfire WOT
Results 1 to 13 of 13
  1. #1 L36 Misfire WOT
    Jun 2017
    Broomall
    So I have a 2000 camaro with a L36 3.8, i was driving today and wound out first gear, car made a wierd noise when i let off. Later, i was driving and the car rapidly misfired around 3500 when at or near WOT. Almost sounded like I was on the teo step just without the backfireing, anyone know whats going on? No SES atm. Any help would be great.
  2. #2 Re: L36 Misfire WOT
    Jun 2017
    Alberta
    The noise sound like a saw blade kind of? For a breif second anyway
    Sent from my SM-G920W8 using Tapatalk
  3. #3 Re: L36 Misfire WOT
    Jun 2017
    Broomall
    Quote Originally Posted by w3tbanana View Post
    Not really... im going to disconect the battery today and drive it again, see if it does anything. Ill also try to get a video and post it on youtube, see if anyone knows whats up
  4. #4 Re: L36 Misfire WOT
    Jun 2017
    Alberta
    Where I was going with that is motor mounts maybe allowing stuff to move around. Might be grinding. My flywheel would rub when I went WOT and let off. Then I threw in some polys and all was good
  5. #5 Re: L36 Misfire WOT
    Jun 2017
    Broomall
    Oh yeah i get what your saying, but nah it wasnt like that tho, i think disconnecting thr battery may have reset it and fixed the issue, car was fine today
  6. #6 Re: L36 Misfire WOT
    May 2017
    Dirtyzville, Mizzery
    Unplug the MAF; see if anything changes. If it does, you have a MAF on the way out. If you haven't it probably wouldn't hurt to change plugs and wires, anyways.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  7. #7 Re: L36 Misfire WOT
    Jun 2017
    Broomall
    Yeah I was playing with the MAF today, apperently my MAF was reading abt 4.5g/s.... (i just learned what this means today, the grams per second should be approx equal to the liters of the motor) so I unplugged the MAF and that didnt do ****, as it got hotter the point were the motor would studder got lower in the rev range (so it happened closer to 2-2.5k), it was a hot day. Turns out my mechanic had the same problem in his monte... said it could be ignition control module, this doesnt sound fun... really hope its just plugs.
  8. #8 Re: L36 Misfire WOT
    clogged cat if its not in need of a tune up.
    icm can be bought at a junk yard super cheap, new they are 100 and up.
  9. #9 Re: L36 Misfire WOT
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Yeah. What Scotty said. If it's the ICM it's a pretty quick and not so expensive repair. 100 for new, 1hr max labor. MAXXX
  10. #10 Re: L36 Misfire WOT
    Jun 2017
    Broomall
    gutted lol
  11. #11 Re: L36 Misfire WOT
    Jun 2017
    Broomall
    Quote Originally Posted by CHI2000GTP View Post
    Is the easy on the camaro though? I know its easy on most 3.8 bc FWD, but its alot more tucked back on the Fbody
  12. #12 Re: L36 Misfire WOT
    if a icm swap takes a hour its time to hang up your man card lol
  13. #13 Re: L36 Misfire WOT
    Enfield, CT
    I agree Scotty
    Sent from my VS995 using Tapatalk
  1. Misfire Help Please!
    By Ryan99639 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2013, 06:48 AM
  2. misfire on hwy
    By justin10morrissey in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2013, 02:39 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Help!!! Misfire
    By Kevin40th in forum General Tech Discussion
    Last Post: 01-30-2010, 09:20 PM
  5. 99 GT Misfire on cyl 6.
    By mazzafamily in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2009, 10:12 AM
