Over the last day or so, I've had the Low Coolant light come on - sometimes for a few minutes then go off (plenty of coolant). Today, the Low Coolant light came on - again for a few minutes, then went off, after a few minutes the ABS light and Lo Trac lights came on. These lights have stayed on.
Plugged the code reader in and no codes are displayed. I thought with a fault indicator like these, at least some codes would display.
right now, I have the battery disconnected - to see if I can clear up the fault, and not sure if this would do anything.
Steering, acceleration, and braking are fine (Have not tried to see if the ABS works or not though)
Anyone have any ideas/suggestions/solutions?
Thanks in advance -
Bill
