Thread: 04' top swap project planning
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: 04' top swap project planning
    SE Level Member keatonregal's Avatar
    Mar 2015
    Port Huron, MI
    I have a GenV for sale in GREAT shape, with a returnless fuel rail and 3 injectors for $180 in Michigan if interested
  2. #22 Re: 04' top swap project planning
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Damn that was fast. Lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #23 Re: 04' top swap project planning
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I have an 04 and did a top swap this spring. Ask me anything. I will help.
    Sell the Gen 3. Get a Gen 5. More efficient and less headaches. Buy a used 04-05 GTP motor so you can get everything at once. Sell what you don't use.
    TBs are the same for GT and GTP. Clean and reuse yours.
    You will need a map and baro sensor (same part #) from a GTP. 2 bar GT vs 3 bar GTP. You will need the bracket, plug, and run a wire to the PCM for the baro sensor.
    Needs heads, intake, fuel injectors, and fuel rail from GTP. Heads will probably have cracks between the valves. Do a valve job and run them with new 90 springs. Fuel injectors are larger in the GTP, plug and play.
    Need GTP pulleys, coil bracket, and other misc stuff. Read the top swap thread for more info.
    Run Speed daddy headers off ebay. Stock catback is fine.
    If you want to run the boost control solenoid for traction control you will need to run a wire to the PCM for it. Otherwise tune it out and disable traction control. I am running it.
    You got the engine out, throw a cam in there. Wait till Black Friday at ZZP and save some money next month or buy a used one on here. Run a new timing chain and tensioner no matter what. Mitigate risk.
    I threw an 04 GTP base tune on mine then had it adjusted from there. I am on a 3.5 pulley for now.
    I pulled, rebuild engine, degreed cam, rebuilt suspension and brakes, and reinstalled in a three day weekend. Prep it all, cherry picker, run air tools, not a bad weekend project. I also installed a TEP trans which you will end up needing when you kill the stock one with new found power. LOL
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  1. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  2. 3800 swap project
    By ADrugDealer in forum Off Topic Discussion
    Last Post: 07-15-2015, 08:30 AM
  3. Replies: 83
    Last Post: 10-05-2014, 12:36 AM
  4. Future planning
    By ND GXP in forum General Grand Prix Discussion
    Last Post: 12-16-2013, 06:00 PM
  5. What LIM can I run if planning a Gen V swap later on?
    By Black18Ice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2009, 07:29 PM
