Thread: P0496 & p1811
Results 1 to 5 of 5
  1. #1 P0496 & p1811
    Oct 2014
    chicago
    So the night before I added half quart of oil I was low on and the next morning I start the car and engine light turns on and get these 2 codes. Probably unrelated to the oil but weird it happened. Any insight on these codes? Can't find them on here
  2. #2 Re: P0496 & p1811
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    DTC P1811 Maximum Adapt and Long Shift
    Here is TEPs explanation on the P1811 http://www.tripleedgeperformance.com...ift-P1811.html
    P0496 on obd-codes.com lists it as "Evap Flow During Non-Purge Condition" weird this one isnt in my pdf of obd codes.
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: P0496 & p1811
    Oct 2014
    chicago
    Thanks for the info on the transmission one will look more into that.and the P0496 I can't really find anything on I think I'm just going to replace the canister purge valve or vent valve solenoid and see what happens with that one.
  4. #4 Re: P0496 & p1811
    Apr 2016
    Maryland
    Did you fix the p0496 code? If so what did you do? I have it now.
  5. #5 Re: P0496 & p1811
    https://www.obd-codes.com/p0496 id start with the canister tank and its parts to and from it.
  1. Fix For P1811?
    By Chadgervais in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-23-2020, 02:32 PM
  2. Top Swap leads to P1811
    By dbextreme in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-13-2013, 06:26 AM
  3. p1811 code fixed
    By bigtee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-11-2010, 04:18 PM
  4. P1811 will not go away
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2008, 06:16 PM
  5. p1811 max adapt-long shift
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2008, 03:21 PM
