Thread: 3.8L lower intake side cover bolts
Results 1 to 7 of 7
  1. #1 3.8L lower intake side cover bolts
    Jul 2016
    Pandora, OH
    Does anyone know the torque spec for the side cover bolts on the lower intake. I have intake off and replacing gaskets and wanted to change out this little cover gasket as well bit can't seem to locate torque specs for these two bolts.
    Thanks
    Dan
  2. #2 Re: 3.8L lower intake side cover bolts
    I'm sure it's in inch pounds but just go snug on them. You do not want to strip the aluminum intake bolt holes.
    Even on the intake manifold itself, I've seen bolts snap even on stock torque specs. Just go nice and snug on everything, the german spec of "good and tight" is plenty.
    Infact I never torque anything on a 3800 unless it's a headgasket or something. Takes too long to spec stuff.
  3. #3 Re: 3.8L lower intake side cover bolts
    hangover park IL
    Iirc its around 89 inch/lbs
    ~James~ Psychotic Gearhead
  4. #4 Re: 3.8L lower intake side cover bolts
    Jul 2016
    Pandora, OH
    Thanks, guys....btw does anyone know what happened to the GPONA website? I am a member over there and that is where I access the service manual and it has been down for the last few weeks. Anyone know what's up?
    Thanks again,
    Dan
  5. #5 Re: 3.8L lower intake side cover bolts
    I think the site is just gone, nothing works there anymore.
  6. #6 Re: 3.8L lower intake side cover bolts
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I put up service manuals for 04+, 90% of the info should be the same as 97-03.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  7. #7 Re: 3.8L lower intake side cover bolts
    Oct 2013
    Clovis, California USA
    I just did mine last week. I did mine wrist tight with a 1/4 drive ratchet. Same torque I put on the throttle body bolts. I did the upper intake at 89 inch pounds though.
  1. Replies: 33
    Last Post: 05-11-2015, 06:21 PM
  2. lower intake bolts
    By krsdadsps in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2014, 07:19 AM
  3. lower intake and supercharger bolts.
    By crashmydaytona in forum Wanted To Buy - Parts
    Last Post: 10-21-2014, 03:44 PM
  4. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  5. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
