Nope. Be ready to break some wires when you try and pull them off. They are easy to fix tho. Just recrimp the end on.
Like removing the plug from the wall...grab and pull the PLUG and not the cord to remove.
Twist clock wise as you gently tug and twist. Works every time.
When you reinstall...put a pea sized drop of dielectric grease in the boot for the plug, as well as the coil. Not only helps keep the moisture out, but keeps the corrosion down, and makes removal next time even easier.
~F~
Thanks a bunch boys.. you guys are great. i will try it this weekend.. its going to be 5 degrees in TO... LOL.. Ill update on the weekend
Jazzy
