Thread: Need Header Help With L36 RWD Application
Results 1 to 7 of 7
  1. #1 Need Header Help With L36 RWD Application
    Jan 2015
    United States
    I have an L36/T5 combo out of a 96 Camaro that I am swapping into a Porsche 944. The stock Camaro headers are center dumps. The center dump causes me trouble clearing things inside my engine bay. It would be better if the dumps were to the rear. Because I am going for California legal smog stuff - I cannot use aftermarket headers. I need FACTORY LOOKING headers with rear dumps that will bolt onto the L36 heads. I repeat - FACTORY LOOKING.
    Does anyone have a suggestion for a GM model car or truck that has rear dump headers that will bolt to an L36 head?
    Thanks for your help!
  2. #2 Re: Need Header Help With L36 RWD Application
    Kemmerer, Wyoming
    pacesetter make L36 camaro headers, not sure how stock looking they are. not sure if the Australians have anything that looks stock or will work but it mighy be worth a shot.
  3. #3 Re: Need Header Help With L36 RWD Application
    Mar 2014
    Tucson
    3.8 Mustang manifolds?
  4. #4 Re: Need Header Help With L36 RWD Application
    Seeing how the 3800 will still be 3800 specific, you won't find anything from another GM car/truck with the same head design and bolt pattern.
    I agree with SGT, look into holden exhaust manifolds.
  5. #5 Re: Need Header Help With L36 RWD Application
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Fiero guys bolt on 3.8l mustang headers with a bit of work to the bolt holes. Might be an option.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  6. #6 Re: Need Header Help With L36 RWD Application
    Dec 2013
    Enfield
    Quote Originally Posted by sparkydog View Post
    The 2000 and up Camaro factory exhaust manifolds are tubular compared to the 96 manifolds you have and supposed to flow better, might be worth a look at if they can be sourced reasonable. Here is an eBay link with some pics.
    http://www.ebay.com/itm/00-01-02-CAM...-/272334023187
  7. #7 Re: Need Header Help With L36 RWD Application
    Jan 2015
    United States
    Thanks very much guys! Both the Mustang and the newer model suggestions look like my ticket. I appreciate your help!
  1. 130# springs to much for my application?
    By grazin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2014, 05:44 PM
  2. WTB: Cam for SC application
    By DOHCZ34 in forum Wanted To Buy - Parts
    Last Post: 09-29-2013, 07:52 PM
  3. vinyl application - milwaukee
    By Bio248 in forum Midwest
    Last Post: 05-04-2011, 12:27 AM
  4. Stoopid online application tests
    By Vegas_Matt in forum The Rant Forum
    Last Post: 04-05-2011, 10:49 PM
  5. transaxle application help needed here
    By overdrive in forum General Tech Discussion
    Last Post: 11-22-2010, 06:58 PM
