Do you're brake light's work? If not it is you're brake pedal switch. That should fix both problems.
If not it could be something associated with the ignition key switch.
As for the lean condition, Most lean conditions on these cars are associated with vacume leaks. I would highly recoment starting there. Just make sure ALL of the hoses ect are on and not dryrotted.
