Thread: 02 GP Coolant Light
Results 1 to 7 of 7
  1. #1 02 GP Coolant Light
    Jun 2014
    Nappanee, IN
    I have a 2002 GP with about 180k miles on it. Recently, the coolant light has been turning on despite there being plenty of coolant in the radiator and the engine running at normal temps (it has a new thermostat/temp gauge). I proceeded to change the coolant level sensor with a junkyard part, but the symptoms didn't change, so i'm assuming there's something else going on here. Has anyone hear of/seen this before? What's the next thing I should look for?
  2. #2 Re: 02 GP Coolant Light
    clean the sensor, or buy a new one. or just unplug it, the light goes out and you never see it again.
  3. #3 Re: 02 GP Coolant Light
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I've bought a new coolant level sensor and the light still showed up. So I just unplugged it and the light goes off don't waste your money on a new sensor.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #4 Re: 02 GP Coolant Light
    Jun 2014
    Nappanee, IN
    Quote Originally Posted by Tonkin2000GT View Post
    Why does this happen? Is the harness going bad?
  5. #5 Re: 02 GP Coolant Light
    Jul 2015
    Jamestown, NY
    I'm not sure it happened to me after I put my new radiator in.
  6. #6 Re: 02 GP Coolant Light
    dex sludge on the sensor. mine is also unplugged, i got a temp gauge, dont need a dummy light.
  7. #7 Re: 02 GP Coolant Light
    GTP Level Member
    Oct 2014
    Quote Originally Posted by Chuppster View Post
    Like Scotty said dex sludge blocks the sensor hole and you can have a full radiator with the sensor sitting here n a pocket of air. Or sludge on the sensor itself.
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. Low Coolant light
    By Points70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2012, 04:30 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
