Thread: knocking on cold start
Results 1 to 20 of 25
  1. #1 knocking on cold start
    May 2016
    dayton oh
    My 02 Grand Prix has a slight knock coming from the engine on cold start but goes away after 2-5 minutes. im assuming its the rotational assembly but my question is can I change out that assembly (new crank or bearings or pistons) without changing the engine. vehicle has 205000 miles on it. any ideas?
  2. #2 Re: knocking on cold start
    sounds like lifter tick. my old 230,000 engine would do this right about 3,000 miles on a oil change. changed the oil it stopped every time.
  3. #3 Re: knocking on cold start
    May 2016
    dayton oh
    Oil has been changed recently, it just started on me about 300 miles after a change. we use 10w-30 oil in it.
  4. #4 Re: knocking on cold start
    I'd try adding some transmission fluid to the oil to maybe free up a sticky lifter.
    You couldn't just swap out a crank/pistons/rods without costing yourself 1000-1500 in machine work. You could buy 3 used motors for that price. Rebuilt 3800's never last.
  5. #5 Re: knocking on cold start
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Lol you guys that say rebuilt 3800's never last is about the dumbest thing ever.... It's a motor it has nothing to do with it being a 3800 if you don't have a retard build it then you shouldn't have any issues.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  6. #6 Re: knocking on cold start
    Quote Originally Posted by Tonkin2000GT View Post
    your so far off. so many fail at re building this engine. it needs shop work and that cost more then a whole used engine, why its not worth it to rebuild one.
    even shops f up rebuilds. so odds are far less in your favor of it staying together for more then 200 miles. thats what we call a back yard rebuild here, a 200 mile engine. thats all they last.
    yes its been done and they live, but is it worth 2500 bucks to you? not me.
  7. #7 Re: knocking on cold start
    May 2016
    dayton oh
    Knocking is coming from the lower end of the motor, from the rod area
  8. #8 Re: knocking on cold start
    and it stops? rod knocks tend to be quiet cold, as the oil warms and thins, you hear it knocking way more.
  9. #9 Re: knocking on cold start
    May 2016
    dayton oh
    it starts making noise when cold then goes away when it warms up.
  10. #10 Re: knocking on cold start
    what your describing sounds more like a lifter, causing rocker clap in the valve cover.
    time to get a stethoscope and listen close.
  11. #11 Re: knocking on cold start
    May 2016
    dayton oh
    Ok, but how would a lifter make a lower engine sound? I put my head to the left side of the motor (There the drive belt is) and it sounds like its coming from the bottom of the vehicle?
  12. #12 Re: knocking on cold start
    put the scope on the oil pan, and the valve cover. you'll know whats louder.
    you can also use a wood dowel, or a large screw driver to your ear.
    typically, rod knock gets worse aka louder as the engine warms up, lifter tick goes away.
  13. #13 Re: knocking on cold start
    Enfield, CT
    Pry bar from covers to ear... Works everytime
    Sent from my LG G3
  14. #14 Re: knocking on cold start
    If it sounds like this, it's a rod knock.
    If it doesnt sound like this, it's a lifter/valvetrain.
  15. #15 Re: knocking on cold start
    May 2016
    dayton oh
    I will listen to the engine later tonight. The noise does not sound like that, its alot quieter than that noise is. I will pinpoint that later
  16. #16 Re: knocking on cold start
    Say that to all the folks that have done all the machine work to a 3800 only to have it break in under 200 miles again.
    Sure some last a little longer but most will just grenade again.
  17. #17 Re: knocking on cold start
    Jul 2015
    Jamestown, NY
    It is to me mine is completely rebuilt by a local guy that builds race motors for our dirt track. The 3800 is basically a 350 with 2 less cylinders set up identical. Anyone that does it for a living and is pretty good at it shouldn't have any issues. Yeah if you take it to a back yard mechanic then I can see that happening but it's not the 3800's fault it's the idiot working on it.
  18. #18 Re: knocking on cold start
    its not a 350, no matter what you say, this block will twist when the crank comes out, its not a simple tear it down, clean it up with new bearings and run with it rebuild.
    it needs machine work or its a fail from the start.
    jamesivey here had a shop re build his, it lasted all of 50 feet. same deal, thats what they do all day, rebuild engines.
    so whats the friend price for a rebuild at your place there? everyone seem to be charged over 2 grand.
    hell one guy who had the shop work done, then re built it himself with his dad, it cost him 2500, his own labor thats shop and parts cost only. lucky for that guy, hes one of the few we know of that are still running strong.
  19. #19 Re: knocking on cold start
    Enfield, CT
    Oh my fvcking god, a 3800 is not a 350 with 2 cylinders shaved off. That would be the 4.3 liter engine. I would know because I used to work at an engine shop and still occainsionally do work there.
    These guys are telling you the complete truth about getting a used engine over a rebuilt one. When my motor blew on my 97 GP, the owner of the shop I worked at even told me I was better off getting one from a junkyard with a warranty and he's been doing this for over 35 years. He's even done NASCAR engines which are extremely technical. Listen to guys like Scott, Bill, Jason, etc, they know what they are talking about.
    Sent from my LG G3
  20. #20 Re: knocking on cold start
    May 2016
    dayton oh
    Yeah my GT is not worth 2500. I was planning anyways to convert it into a GTP so just getting another engine makes sense from the start. Im just trying to band-aide this motor until my SC motor is built. That engine is being machined and tuned since Im trying to turn it into a high performance vehicle. But the NA motor is not worth all that time and effort in my opinion. Thanks guys for all the infos and tips. Maybe once I get the SC motor started you guys can give me some tips?
  1. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  2. pontiac grand prix 3.8L ticking knocking noise when cold
    By gumby21ne in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-13-2014, 10:42 PM
  3. Whine on a cold start
    By Grandprix202 in forum Engine
    Last Post: 11-18-2014, 02:03 PM
  4. Cold start problems
    By jmn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2012, 10:43 PM
  5. e85 cold start
    By gtpsleeper in forum PCM Tuning
    Last Post: 01-03-2012, 12:35 PM
