Thread: MAP sensor
Results 1 to 12 of 12
  1. #1 MAP sensor
    GTP Level Member
    Oct 2014
    I was changing my PVC valve on my 2008 GP and the MAP sensor came apart while unhooking the PVC holder clip. It kind of snapped together but not really. I'm guessing they are not to come apart.
    I put it back together and the clip holds it in and it idled fine. But thinking I should order a replacement. Thoughts? Epoxy the old one together?
  2. #2 Re: MAP sensor
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Do you mean you broke one of the little "ears" on the plastic holder for the MAP sensor?
    If so, you can get one at the junkyard, or, the "help!" section at advance auto should have a dorman replacement.
    http://shop.advanceautoparts.com/p/d...rm=dorman+help
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  3. #3 Re: MAP sensor
    GTP Level Member
    Oct 2014
    No. The actual rectangular plastic piece with the orange rubber piece that fits in that plastic holder separated from the larger part of the MAP sensor where the wires plug in and has the tabs that the snap into the plastics holder. It did lot look like it should have came apart. Almost like heat or age rotted plastic but was a very clean break then and kind of fit back together. We will see how it drives this am. I ordered a new one in case it is bad.
    Sent from my iPad using Tapatalk
  4. #4 Re: MAP sensor
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Take a pic of it.
  5. #5 Re: MAP sensor
    GTP Level Member
    Oct 2014
    Good idea.
    Still drove fine. Just doesn't seem like it should come apart.
  6. #6 Re: MAP sensor
    Kemmerer, Wyoming
    that's not good. it should be easy to find a 1 bar map sensor. I think any map sensor from a non supercharged 99+ will work. I have an extra one if you want to pay 5 dollars plus whatever shipping ends up being.
  7. #7 Re: MAP sensor
    GTP Level Member
    Oct 2014
    I got one ordered cheap and free shipping. But thanks for the offer. If it measures pressure wonder why it works with 4 big cracks in it.
  8. #8 Re: MAP sensor
    Kemmerer, Wyoming
    good deal. my neighbor has a 2001 GTP, and the MAF sensor was failing, after we changed it, we looked at his failing sensor, and it did the same exact thing as your map sensor.
  9. #9 Re: MAP sensor
    May 2012
    Bloomington, IN
    careful about cheap GM sensors that aren't AC Delco or a high end equivalent. I ordered a budget MAP sensor and started having EGR codes pop up regularly afterwards. It wasn't the EGR or EGR pipe which was bad, it was a crappy MAP sensor throwing off everything else. From experience, budget GM sensors are best to be avoided. I learned the hard way with budget crank sensor (stranded me on the highway) and ignition control modules (resulted in a melted ignition coil). Spend the money now to avoid the headache later. my 2 cents.
  10. #10 Re: MAP sensor
    GTP Level Member
    Oct 2014
    I got an AC Delco off amazon prime for like 40 bucks. Not super cheap but cheaper than rock auto. And arrives tomorrow. 😉
  11. #11 Re: MAP sensor
    Kemmerer, Wyoming
    It's hard to beat that free 2 day shipping if you have a prime account. Rock auto is only better because you can find stuff easier and they have more products, and sometimes the price is better
  12. #12 Re: MAP sensor
    GTP Level Member
    Oct 2014
    Yes I love rock auto. Usually start there and then put part number into eBay / Amazon and if I need it quick use my daughters collage prime account. Rock autos prices are thought to beat but their shipping throws them out of the game every once in a while.
  1. Replies: 7
    Last Post: 01-31-2015, 07:12 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
