What kind of gains could I expect after add down pipe,pcm cam and torque converter to my l26. And what other adds do you recommend for a goal of 400 to 500 hp
If you're n/a, you need a turbo or supercharger to get to those kind of numbers
Have you looked at any dyno charts from m90/cam/heads builds?
Nitrous.![]()
400 at the crank? Yes. E85, cam, tiny pulley, maybe intercooler. Very doable on a m90 setup. But turbo will make more and probably cost the same, maybe less.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Hope you know how to build an trans
Bolt on engine goodies? ZZP or used in the classifieds.
As for trans upgrades, TEP.
This is mostly true. But not driving like an idiot goes a long way. I've been around 300whp for over a year and only a shift kit in my stock trans and it's still doing great. I might be on borrowed time, but if you don't go WOT every shift you make, you can make the stock one last a bit with some general maintenance
^^^^^your driving habits will for sure dictate the tranns life span. im likely close to 300 crank hp on a stock tranny with just a shift kit myself, its holding fine with 150,000 on it.
its when you add a cam, or a turbo stuff starts to break. the flex plate and input shaft are the first victims. stock flex plates crack under stock HP.
you must be on tap talk, its in his sig
Comp G. E85, 3.0, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
my weak ass list next to his lol
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, 3.0, FSIC, 42 lb injectors,
Probably not too much of a difference between me and Scotty honestly. Cam adds maybe 20-30 hp over his rockers and his intercooler is the equal to my e85. I've dynoed mine a few times on this setup and a 3.0 and had as high as 307whp. I could probably add a catback exhaust (I'm still stock there) and go to a 2.8 and gain another 15 or 20 at the wheels. But as is its pretty quick.
