ok guys im going to get stock l36 motor and do a top swap and few other things...... cam, heads,meth,10:1 compression, blah blah blah. more then likly the motor i will be getting will have 100k to 125k on it. im wondering if i should replace the rod and main bearings in it? and if i take the crank out and match all the rods and pistons to the same weight will it effect over all balance to where i would have to rebalance it? how much does it cost to rebalance the rotating assembly? (50% balance). or would i be better off to leave it alone and bolt everything up and beat the pi$$ out of it? also i thinking of opening up the main bearing oil holes so there all the same size and add the intense oil filter relocation kit so i can adjust oil psi.
im on a budget but if it makes it last in the long run ill put down the cash to a point! no forged internals here.
thanks
chris
