Thread: Exhaust nut & bolt suggestions
Results 1 to 3 of 3
  1. #1 Exhaust nut & bolt suggestions
    May 2012
    Bloomington, IN
    I have a clogged cat (2004) and I will be replacing the downpipe. I believe the two bolts that secure the downpipe to the catback are 15mm bolts (although I've also seen 14mm posted elsewhere). I want to replace these nuts and bolts along with the 13mm nuts on the downpipe to manifold connection. While i'm at it anyone know the thread pitch to these off the top of their head, I haven't looked yet which i could do...
    I wasn't sure if grade 8 zinc coated would work well or perhaps something else. I plan on using copper anti-seize as it looks like a muffler replacement isn't too far away. Let me know any tricks or decent materials to use to avoid the rust on the hardware, thanks.
  2. #2 Re: Exhaust nut & bolt suggestions
    No idea on thread pitch or anything like that.
    Just get bolts that fit is what I do. Stainless bolts/nuts or using a anti-seize will work just fine on grade 8 bolts.
  3. #3 Re: Exhaust nut & bolt suggestions
    If it's an M8 it should be 1.25 pitch and M10 will be 1.50 pitch. GM was good about keeping it all the same.
    15mm nut should be an M10 and 13mm should be M8. If it comes out as a 14mm, then it's a rusted 15mm.
  1. Exhaust suggestions?
    By Rnungaray08 in forum 5.3L V8 (LS4)
    Last Post: 12-28-2014, 12:06 PM
  2. exhaust suggestions
    By carr08 in forum General Grand Prix Discussion
    Last Post: 05-14-2012, 04:09 PM
  3. Suggestions on exhaust
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 01:34 AM
  4. exhaust, any suggestions
    By mtz956 in forum General Tech Discussion
    Last Post: 02-10-2011, 12:54 PM
  5. Exhaust Suggestions
    By zebulun in forum 5.3L V8 (LS4)
    Last Post: 09-01-2010, 10:14 AM
