Thread: RTV silicone suggestions, LIM valley oil leak
Results 1 to 13 of 13
  1. #1 RTV silicone suggestions, LIM valley oil leak
    May 2012
    Bloomington, IN
    I swapped out my LIM gaskets at around 145k I'm not at 206k and I think I have a LIM valley gasket, or rtv silicone leak where there is a gap between the LIM gaskets. I believe this is the case as I have oil that would appear to be coming out of both head gaskets on one side of the engine. I've been reading a bit and the LIM valley/rtv site can leak and appear to be coming from the HGs which I know is a pretty rare event for oil to actually be coming out of them.
    When I did the install way back when I had a guy who knew how to do it help. He poured a whole helping of rtv on the LIM and valley gasket including where the gap is. I was a little concerned about the amount of rtv as it doesn't look like you needed that much. I'm not sure if this is now the point of failure or not but wanted to get any suggestions of rtv that might last longer than the 60k I've gotten out of it.
    I also went from parking indoors to outdoors (cold winters) so I'm also not sure if that had anything to do with the leak as I'm leaking in a few other seals, but I imagine that's a combination of the mileage, and grooves worn into the axles and crank seals. I've managed to fix the front crank seal for now.
    Let me know if there are any quality rtv that might last longer than 60k, thanks.
  2. #2 Re: RTV silicone suggestions, LIM valley oil leak
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I'll let Bill take this one lol.
  3. #3 Re: RTV silicone suggestions, LIM valley oil leak
    Buffalo
    Right stuff by permatex - I use it on everything
  4. #4 Re: RTV silicone suggestions, LIM valley oil leak
    Buffalo
    Lol why ? Is Bill a silicone expert ?
  5. #5 Re: RTV silicone suggestions, LIM valley oil leak
    Apr 2015
    Quote Originally Posted by CrazyGuy03 View Post
    No, but he has a good lesson about those little end pieces on the LIM. At one point his fell into the engine...
  6. #6 Re: RTV silicone suggestions, LIM valley oil leak
    Buffalo
    Is super simple. Easily done I mean. It's even printed on the little piece of paper included with the gasket.
  7. #7 Re: RTV silicone suggestions, LIM valley oil leak
    Clean it down.. I bet you'll find it's your valve cover gaskets and grommets that need to be replaced.
    You are correct, it's nearly impossible for HG's to leak oil. Nearly as in you'll win powerball first.
  8. #8 Re: RTV silicone suggestions, LIM valley oil leak
    Jul 2010
    Coquitlam,BC,Canada
    Black RTV silicone.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: RTV silicone suggestions, LIM valley oil leak
    Ultra copper
  10. #10 Re: RTV silicone suggestions, LIM valley oil leak
    Buffalo
    See. We all got our favorites. Just effin do it correctly and don't worry
    I'll tell you why no one uses my choice of rtv - $$. But it's to me
    as e85 is to Tyler....
  11. #11 Re: RTV silicone suggestions, LIM valley oil leak
    May 2012
    Bloomington, IN
    Yeah my valve cover gaskets have about 20k on them and the grommets about 5k, yes I didn't do them at the same time...
    But could it be the LIM valley rtf that has failed. I have the slightly older felpro plastic gaskets and want to upgrade to the newer felpro metal.
    People would suggest copper rtv has a good alternative to generic black rtv
  12. #12 Re: RTV silicone suggestions, LIM valley oil leak
    i dab rtv on the bare metal @ the corners and set the gaskets in, then another dab @ the corners.
    that areas not leaking oil, trust me on that. its your valve covers.
    black rtv is fine, red is fine, orange is fine, grey is also fine. any rtv will work for the corner dabs, makes no difference at all.
  13. #13 Re: RTV silicone suggestions, LIM valley oil leak
    Enfield, CT
    X2.
    Sent from my LG G3
  1. lim end gaskets or silicone?
    By 91z in forum General Tech Discussion
    Last Post: 09-05-2010, 02:59 PM
  2. silicone gasket need help quick...
    Last Post: 09-01-2009, 07:24 PM
  3. Hello from Apple Valley, MN
    By jloesch78 in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:12 AM
