Thread: Power gains
Results 1 to 20 of 31
  1. #1 Power gains
    SE Level Member drenolov's Avatar
    Nov 2014
    What kind of gains could I expect after add down pipe,pcm cam and torque converter to my l26. And what other adds do you recommend for a goal of 400 to 500 hp
  2. #2 Re: Power gains
    Buffalo
    If you're n/a, you need a turbo or supercharger to get to those kind of numbers
  3. #3 Re: Power gains
    Nov 2014
    Quote Originally Posted by CrazyGuy03 View Post
    Can it be done with just sc
  4. #4 Re: Power gains
    Buffalo
    Have you looked at any dyno charts from m90/cam/heads builds?
  5. #5 Re: Power gains
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Nitrous.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  6. #6 Re: Power gains
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    400 at the crank? Yes. E85, cam, tiny pulley, maybe intercooler. Very doable on a m90 setup. But turbo will make more and probably cost the same, maybe less.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  7. #7 Re: Power gains
    Nov 2014
    Quote Originally Posted by chrsmi1 View Post
    Ok so I'm Wreck-It Ralph going Turbo
  8. #8 Re: Power gains
    Buffalo
    Hope you know how to build an trans
  9. #9 Re: Power gains
    Nov 2014
    How much torque does a stock trans good for
  10. #10 Re: Power gains
    trans fails at 300-350 hp. anything more you really need a 3 to 4000 dollar tranny built. lots of expensive hard parts are needed.
  11. #11 Re: Power gains
    Nov 2014
    Where's the best after market 3800 parts zzp,intense or
  12. #12 Re: Power gains
    TEP, they are a sponsor here. have a banner at top the page. triple edge performance. many many many guys have ordered built trannys from them.
  13. #13 Re: Power gains
    Aug 2011
    Gahanna, Ohio
    Bolt on engine goodies? ZZP or used in the classifieds .
    As for trans upgrades, TEP.
  14. #14 Re: Power gains
    Jan 2013
    Raleigh, NC
    This is mostly true. But not driving like an idiot goes a long way. I've been around 300whp for over a year and only a shift kit in my stock trans and it's still doing great. I might be on borrowed time, but if you don't go WOT every shift you make, you can make the stock one last a bit with some general maintenance
  15. #15 Re: Power gains
    ^^^^^your driving habits will for sure dictate the tranns life span. im likely close to 300 crank hp on a stock tranny with just a shift kit myself, its holding fine with 150,000 on it.
    its when you add a cam, or a turbo stuff starts to break. the flex plate and input shaft are the first victims. stock flex plates crack under stock HP.
  16. #16 Re: Power gains
    Nov 2014
    Chrsmi1 are you running l 67 or l36 what upgrades do you have
  17. #17 Re: Power gains
    you must be on tap talk, its in his sig
    Comp G. E85, 3.0, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    my weak ass list next to his lol
    L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, 3.0, FSIC, 42 lb injectors,
  18. #18 Re: Power gains
    Jan 2013
    Raleigh, NC
    Probably not too much of a difference between me and Scotty honestly. Cam adds maybe 20-30 hp over his rockers and his intercooler is the equal to my e85. I've dynoed mine a few times on this setup and a 3.0 and had as high as 307whp. I could probably add a catback exhaust (I'm still stock there) and go to a 2.8 and gain another 15 or 20 at the wheels. But as is its pretty quick.
  19. #19 Re: Power gains
    Nov 2014
    What are the 3.0 and fsic what #s are you putting out
  20. #20 Re: Power gains
    Nov 2014
    Ok so you don't have a lot of mods other than cam and e85 did you change any thing to run e85 I was have sleep and put e85 in my car and it locked up
  1. Any power gains / KR reduction from removing the resonator?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 06-18-2014, 02:32 PM
  2. Gen v N* lq4 maf gains
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2013, 04:07 PM
  3. Significant gains from headers over power log?
    By bps02gtp in forum General Tech Discussion
    Last Post: 04-28-2012, 02:16 PM
  4. where is my power gains??????
    By novmadman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2011, 09:33 AM
  5. power and torque gains?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2010, 04:05 PM
