Thread: Low Oil
Results 1 to 19 of 19
  1. #1 Low Oil
    Aug 2011
    'Merica
    My car has been yelling at me for low oil level for 3 days, what do I do?
  2. #2 Re: Low Oil
    keep driving it. buy new car when it stops running.
  3. #3 Re: Low Oil
    Aug 2011
    'Merica
    I think my blinker fluid is low too where do i find that at?
  4. #4 Re: Low Oil
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by Below Average Joe View Post
    You go ask Jason how.
  5. #5 Re: Low Oil
    Remove the dash cluster and just take the bulb out, it's a completely useless feature on these cars.
  6. #6 Re: Low Oil
    Jan 2014
    AR
    Give this man a chicken dinner, thats exactly how I would handle this.
  7. #7 Re: Low Oil
    Aug 2011
    'Merica
    05 so the DIC tells me whats going on. Not overly concerned since I have oil in the garage. Just need to stop being lazy and get it done.
  8. #8 Re: Low Oil
    I was being sarcastic, as with most of us I think.
    The feature is a good one, when working correctly they can save your ass if it indeed burns oil.
    Other than making sure it's full, the sensor or the wires can be bad.
  9. #9 Re: Low Oil
    Aug 2011
    'Merica
    pretty sure the sensor is leaking around it iirc. It was pretty wet around it the last time I was under the car. I'm just too lazy.
  10. #10 Re: Low Oil
    Apr 2015
    Honestly, I thought your original post was being serious.
  11. #11 Re: Low Oil
    hangover park IL
    it is a rather useless feature, but it has its merits for those inclined to ignore things or some such....
    on the old cars the oil level "dildo" had all the level electronics n **** in a clear tube. the new ones use the pcm software to do the same 'averaging"
    its primarily looked at on cold starts, when oil is think and tends to hangout in the topend longer before it drains back down, when the sensor is triggered it will trigger the dic warning/oil level light. the sensor is always active /open and closing.
    the old SI 3800 sensors are quite interesting, powered through the low oil level light, and grounding through the circuits averaged this measurement style internally to trigger a dumb light once its limit is reached it would latch the output to ground till power was removed.
    ....if the bulb burned out or the INST LMPS power fuse was blown the bugger wouldnt work.
    im using an old style "dumb light" unit in my cressida to operate the toyota cluster light
    ~James~ Psychotic Gearhead
  12. #12 Re: Low Oil
    hangover park IL
  13. #13 Re: Low Oil
    Enfield, CT
    There's oil in cars?
  14. #14 Re: Low Oil
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    It means it's time to grease the muffler bearing
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  15. #15 Re: Low Oil
    hangover park IL
    put a quart of earl in the car, remove the "710" cap to do so
  16. #16 Re: Low Oil
    Jan 2014
    AR
    My reply was also sarcastic, just playing along. I actually let one of mine get that low once... oh no, wait... once when mine was wrecked, the just-borrowed S-10 had that light come on when I shifted to second. It was two quarts down and I didn't go two more blocks before filling it. Never had a 3800 leak like that myself.
  17. #17 Re: Low Oil
    I laugh at the Audi guys who complain about a quart every 5K miles being considered normal by Audi.. yet GM says one quart every 3K miles.
  18. #18 Re: Low Oil
    Enfield, CT
    You really shouldn't lose oil anyways
    Sent from my LG G3
  19. #19 Re: Low Oil
    Pennsylvania, USA
    Certain Honda engines have issues with their piston rings, and in the SB they aren't covered by Honda for replacement unless the vehicle is using more than a quart o oil every 1K. The older Accords and CR-V's. I think we've had 5 vehicles through in the past month.
    A quart every 3K or 5K is amazing in comparison.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
