Thread: High idle?
Results 1 to 20 of 25
  1. #1 High idle?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Can somebody tell me what cause the idle on my car to be so high. I replaced the maf, map, iac valve, the entire air intake, the ICM and coil packs, spark plugs and wires, the ICM, fuel filter, fuel pump. So I'm not understanding why it's not running normally
    Sent from my SM-N910T using Tapatalk
  2. #2 Re: High idle?
    how high it it?
  3. #3 Re: High idle?
    Sep 2014
    New Orleans
    It shoots up to 2 on the tach 1 minute after I start the engine
  4. #4 Re: High idle?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Throttle body cleaned?
  5. #5 Re: High idle?
    Sep 2014
    New Orleans
    Quote Originally Posted by SubwayBrat View Post
    How to clean it?
  6. #6 Re: High idle?
    vac leak or the tb is filthy dirty.
    being na, pull the vac line off the fpr on the fuel rail, sniff the vac line for gas, or if gas comes out of the line the fpr is bad.
  7. #7 Re: High idle?
    Apr 2015
    Pull the TB off and clean it. There's 3 bolts holding it on. I'm betting it's blacker than black inside. Be sure to take the mesh screen off and MAF sensor out when you clean it. Also a little coolant will come out to.
  8. #8 Re: High idle?
    Sep 2014
    New Orleans
    Quote Originally Posted by ScottyDoggs View Post
    No gas came out of the fuel pressure regulator
  9. #9 Re: High idle?
    Sep 2014
    New Orleans
    What should I use to clean the throttle body
  10. #10 Re: High idle?
    carb cleaner works. or brake cleaner. take the maf out first, you dont want any cleaner to hit it, or its dead.
  11. #11 Re: High idle?
    You may also want to unhook the throttle and cruise cables, start it up.. if it runs normally you should adjust the cabling on top of the strut tower. I've seen it move when people are working on the car and somehow that allows it to put pressure on the throttle, which keeps it open,.
  12. #12 Re: High idle?
    Sep 2014
    New Orleans
    If I start the car up with the maf plugged then unplug it after it starts. And the car don't die. What do that mean
  13. #13 Re: High idle?
    means your maf is crap, get a oem one used from a junk yard, or pony up for delco maf.
    you just learned how aftermarket mafs dont work.
  14. #14 Re: High idle?
    Sep 2014
    New Orleans
    Ok and it didn't die immediately when I unplugged it but it died about 2 minutes later
  15. #15 Re: High idle?
    you dont unplug it car running....pay attention.
    car off, un plug it, start it, if it runs better unplugged the maf is crapped out.
    dont try to plug it in car running either, your just confusing the computer.
  16. #16 Re: High idle?
    Sep 2014
    New Orleans
    Ok but what if it still die after 2 minutes of driving it unplugged
  17. #17 Re: High idle?
    you still have the stock maf? if you do put it back in.
    you fix your vac leaks?
  18. #18 Re: High idle?
    Sep 2014
    New Orleans
    No when I took it out of the tb the bottom piece of the maf broke off and I'll check my vac lines again
  19. #19 Re: High idle?
    and in one of your many threads your check engine light never lit up? was that you? ( why you dont start 10 threads for the same issue)
    if thats you did you ever get it scanned for codes?
  20. #20 Re: High idle?
    Sep 2014
    New Orleans
    My check engine light never came on
  1. High Idle
    By rvnwlf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2015, 11:16 AM
  2. High Idle
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2013, 11:12 PM
  3. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  4. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
