Thread: UIM question
Results 1 to 11 of 11
  1. #1 UIM question
    Jan 2016
    indiana
    Hi all, first post.
    In the prosses of doing UIM and LIM.
    On the UIM, the center bore below the throttle body on mine has caved in a little from corosion Will this cause issues down the road? Should i get a new one ( dorman or atp? ) ?
    Any reply apriciated!!
    UIM question Attached Images
  2. #2 Re: UIM question
    Kemmerer, Wyoming
    that sh!t doesn't matter, just replace the gasket if you are that worried about it
  3. #3 Re: UIM question
    Jan 2016
    indiana
    Quote Originally Posted by SgtMarshal View Post
    hey dude. sorry for the crap photo.
    heres a clearer shot, not the gasket but the center small hole at the bottom of the bore. the plastic lip is cracked.
    this hole is a dead hole, but infront of the stove top.
  4. #4 Re: UIM question
    You should replace the UIM.
  5. #5 Re: UIM question
    Kemmerer, Wyoming
    you should be able to get an upper intake manifold pretty cheap if you look around on here and get a used one
  6. #6 Re: UIM question
    Jan 2016
    indiana
    thats what i thought :/ ill pick up a dorman today.
    thanks for your responses!
  7. #7 Re: UIM question
    Kemmerer, Wyoming
    I think there was something wrong with the dormans
  8. #8 Re: UIM question
    Jan 2016
    indiana
    do you remember what?
    ive read alot of mixed reviews on both Dorman and ATP. dealing with bolt holes not lining up and over torquing causing cracks.
    been looking for updated info to see if ither company has resolved the issues.
    but i did pick up Dorman kit, and the UIM is noticeably heavier then my stock one.
  9. #9 Re: UIM question
    the only thing wrong with a dorman is you.
    Here's how they like to fail
    http://www.grandprixforums.net/threa...highlight=easy
    If you follow this and plug the coolant ports, you'll never have the coolant in the UIM to drown the engine
  10. #10 Re: UIM question
    Oct 2013
    Dillon MT
    Subscribed...wanting to know the same thing. I'm also doing the LIM and UIM gaskets, as well as valve covers and all new hoses.
  11. #11 Re: UIM question
    Jan 2016
    indiana
    Quote Originally Posted by skills4lou View Post
    I just finished mine this morning. i ended up using the Felpro lower and upper gaskets with Dorman intake manifold. also valve covers, FP regulator, plugs & wires, water pump.
    So far so good with a test drive, no leaks.
    i only had one bolt hole on the Dorman that was a hair harder to get in.
    but i was worrried about the UIM gasket fitting the Dorman intake. both Felpro and the Dorman gasket seemed short to lock in to the intake. with a little force they both did, not sure if thats normal. once torqued, nothing seemed to snap or break. so i hope its good
    also hope this fixes my warm start sputter..
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
