mines not really the same as yours. my evap is on the back. fat hose to tb, smaller hose pushed inside it, then smaller hose to hard line. its the one bending backwards in the sun glare.
the zip ties are keeping his cable in line with the channel in the bracket.if he cuts them the cables will separate, rub on the bracket and break. i dont think there is a way to put a new plastic retainer on the cable. i believe the only fix is a entire jy cable.
pinch the square block on the fire wall woth pliers and pull it out. you need to unhook the cable from the gas pedal, look up its rather easy to get the cable off the arm.
