Thread: cracking noise after lca
Results 1 to 4 of 4
  1. #1 cracking noise after lca
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I recently changed my front control arm on each Yt and the complete axle shaft on drivers side bcuz thr boot was ripped and nvr noticed.
    Anyway, i hear a cracking noise everytime i turn the wheel. And it wasn't present before. I started with front torx bolt then i put the ball joint on and lastly the back bolt, but to get the back bolt on i had to turn the wheel to line it up. Then i tightened everything up while it was jacked up w no load. I bought new stabilizer links again tightened that up w no load and i didn't use a torque wrench. Should i be redoin this?? Thanks
  2. #2 Re: cracking noise after lca
    Last time I had a cracking/creaking noise in the front end...it ended up being the rack.
    I replaced inner/outer tie rods, hubs, LCA's, End Links, etc.
    Nothing changed it, because it ended up being the gear in the rack itself was cracking about under steering load once there was resistance put on it...because up in the air it didn't do it.
  3. #3 Re: cracking noise after lca
    Nov 2011
    north bay, ontario
    Thanks, im gonna take a look at the rack. Hopefully theres a how to on that. One thing i did notice tho is that the hole on the lca for the stab. Link is located closer towards the tranny side by about 2" or so. I believe i hv a 32mm bar and the listing called for a 24mm bar. Maybe my links are under stress, causing that crack. Or my stabilizer bar needs to be swapped out w a 24mm bar.
  4. #4 Re: cracking noise after lca
    Pretty sure the Comp G had a larger FSB but I could be wrong.
    I do know the 04+ LCA is specific to it...97-03 is different.
  1. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  2. AC noise??
    By grandprix85 in forum General Tech Discussion
    Last Post: 07-20-2011, 08:07 AM
  3. Static and cracking sound from door and dash speaker
    By DeweyMFD in forum Audio, Security & Visual Electronics
    Last Post: 06-04-2011, 11:14 AM
  4. Outside window seal cracking... Pics
    By chevyy1212 in forum General Tech Discussion
    Last Post: 05-18-2011, 08:58 PM
  5. You Tube Cracking down!
    By David99GTP in forum The Rant Forum
    Last Post: 02-11-2009, 12:32 PM
