My car is having the exact same problem. As Synthetic asked, my car is shifting hard, and stalling out at idle and initial acceleration. As stanwich describes on his car, my car also has misfire sounds when at idle, and shudders when I give it some gas. I did some research, and as FlatlinerD described, he needed a new fuel pump resistor. I have 131,xxx miles on my car, so I'm thinking this could also be an issue. I did a scan on my HPTuners and these are the codes I got.
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency (History)(Immature)
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage (SES)(Old)(History)(Current)(Immature)
P0141 HO2S Heater Performance Bank 1 Sensor 2 (Old)(Immature)
P1111 Intake Air temperature (IAT) Sensor Circuit Intermittent High Voltage (Old)(History)(Current)(Immature)
I guess the good news is I didn't get any of the codes mentioned on Dave's transmission information page on his website, Triple Edge Performance.
4T65E Transmission Info
However, while coming into work tonight, I stopped at a red light. Luckily it was right next to my job. It was around 11:40PM. My car surged and started accelerating. I eased off the brake to prepare for worst case scenario red line. It did this several times at the light. The P1811 code never went off. Dave said on his website, "this code will not set the SES light but will disable all adaptive shifts and will max out line pressure in the transmission which causes the harsh shifts and can also cause the transmission pump to whine because it is supplying fluid at a high rate and pressure and puts more stress on it thus creating the whine. Generally shutting off the car will make this condition go away until you drive a few more miles or the vehicle warms up and the harsh shifting will return." (tripleedgeperformance.com) The harsh shifting does disappear after I turn off the car, and it starts increasing slowly on my trip to home, and to work. I don't notice any transmission pump whining, but maybe I don't know exactly what I'm listening for.
This issue is what leads me to believe I have two separate problems rather than one. I think I need to replace my Pressure Control (EPC) Solenoid, which according to Dave's website, is the problem. Any more information would be well appreciated on replacing this part. Dave's website said I'll have to hoist the engine, drop the transmission, remove the driver side axle, and more. However that was a generalization of what will probably be done on a wide range of front wheel drive cars. I need the information for the 4T65E-HD.
By the way, my transmission fluid level is fine, as well as it's texture seems to be good, just to clear this issue out of the way. I had been checking my transmission fluid since the first sign of harsh shifting, and checked it tonight around 1:00AM after the surge attack.
I think for my other issues of stalling, and shuddered acceleration I will replace or upgrade the parts needed.
First of all, my IAT sensor seems to be damaged, and this may have been my fault. When I made my intake I didn't cut a bung for it, and let it hang. It may have been damaged while bobbling around. I don't think this is the cause of my problems, but probably could effect them to an extent. The sensor is now installed into TDC Racings intake. Luckily for me, I ordered a new sensor from Reptile earlier this week, so this issue should be fixed, no problem.
I am also going to change my fuel filter. I was going to change it anyways. Any suggestions on what brand filter I should go with, or should I just stick to GM?
The Fuel Pressure regulator check seems like a good idea. I will try that. I will probably just go ahead and replace it with an aftermarket piece because with what I plan on doing to my car, I'm going to need a high flowing one anyways.
Since these issues came up it may be a good idea to get a fuel pressure gauge. Where would be a good place to tap in a gauge on our cars to measure the pressure?
I may need to replace my fuel pump resistor as well.
Fuel Pump Resistor - 97-03 Grand Prix - PFYC
I have a few Walbro 255lph HP fuel pumps lying around from my Talon. I think I'll put one on along with a fuel pump rewire kit. When I first installed a high flow pump on my Talon I noticed a loud wind sound coming from my car. I didn't realize it was the pump at the time, but after doing research on DSMtuners.com and other sites I discovered that the issue could be low voltage to the pump. I bought a rewire kit and sure enough the sound went away. I didn't have a pressure gauge on the car at the time so I don't know how much the flow increased, but their is a lot of feedback that says it is a needed upgrade.
Or my other option is this.
Caspers Electronics Fuel Pump Hotwire Kit: 3800 Performance It's a fuel pump rewire that bypasses the fuel pressure resistor. I think this is my best option because I wouldn't have to worry about the resistor anymore, and it would save me about $10-15 if buying the resistor and re-wire separately.
I think I'll throw in an alternator booster just for kicks as well.
Other potential problems could be I need to replace my Autolite 104's already.
Hopefully after all this my issues will be resolved. My fingers are crossed!!! Thanks to all who will help!
