Thread: TPS wiring question
Results 1 to 2 of 2
  1. #1 TPS wiring question
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    2001 Grand Prix GT
    Alright so checking between the PCM and the TPS connector when plugged in all three wires are getting numbers when I use both TPS pins in the PCM when checking the resistance between them. So I think this means they are open or shorted together. But how can they be???
    The TPS is plugged into the Engine Coolant Temp sensor and that's it! I'm so lost.
    And according to this diagram
    It says an orange and black wire should be spliced into the MAP sensor?? Is this right? Because I don't think it ever has.
  2. #2 Re: TPS wiring question
    Nov 2010
    Found issue. Thank you
  1. Quick DVC Sub Wiring Question
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2013, 08:17 PM
  2. Quick question with wiring...
    By BCUZ RACECAR in forum General Tech Discussion
    Last Post: 09-20-2012, 02:30 PM
  3. HID wiring question
    By chi_town in forum General Tech Discussion
    Last Post: 09-19-2012, 01:25 AM
  4. GP GT Wiring Question!
    By Grandprix2010 in forum General Tech Discussion
    Last Post: 03-19-2010, 08:42 AM
  5. question about wiring harness.
    By WayneG99 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2009, 02:02 PM
