Thread: Temp gauge problem after coolant temp sensor change.
Results 1 to 7 of 7
  1. #1 Temp gauge problem after coolant temp sensor change.
    SE Level Member Beast388's Avatar
    Jul 2010
    Iowa
    I changed the coolant temp sensor this weekend in my '01 GP, refilled with Dexcool and bled the system. My temp gauge on the dash now reads incorrectly. When I start the car, the gauge reads 160, but then slowly climbs up to 260 and stays there regardless of engine temp. It was 28*F this morning, and the gauge was pegged at 260 within two block of my house.
    Later today I will hook up a scanner to the ODBII port to see what the PCM is seeing for temp. When the gauge pegs out, the fans do not come on...so I am thinking that the sensor wiring might be the culprit, or I have a bad sensor.
    Has anyone else experienced something similar?
    2001 Grand Prix GT - Dark Bronzemist Metallic
  2. #2 Re: Temp gauge problem after coolant temp sensor change.
    I'd say you got a bad sensor.
    I just changed one on saturday and they do suck because of the tight space.
  3. #3 Re: Temp gauge problem after coolant temp sensor change.
    Jul 2010
    Iowa
    Scanner shows that the PCM is seeing 195*F when the gauge is pegged at 260*F. Time to take back the crap Napa sensor and order an AC Delco.
  4. #4 Re: Temp gauge problem after coolant temp sensor change.
    GTP Level Member
    springfield IL
    i had same issue with an "napa" brand bout 10 yrs ago.. also wasted over $200 with a stupid mechanic than bowled with my father at the time.
    got an ac delco and changed it myself. first time i worked on a vehicle so it was a moral victory also!!!! hahahaha
  5. #5 Re: Temp gauge problem after coolant temp sensor change.
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    When it comes to sensors on this car, OEM is your only option for correct readings. Also the temp guages are known to be off from the factory.
  6. #6 Re: Temp gauge problem after coolant temp sensor change.
    I used a napa part, it worked just fine.
    They are known to be bad out of the box all the time no matter the brand really, cheaper parts being more prone to the issue.
  7. #7 Re: Temp gauge problem after coolant temp sensor change.
    Apr 2015
    But with actual GM brands, those failure chances are reduced by even more to basically none. You don't hear a lot of people say their Delphi or Delco sensor didn't work out of the box. It's more of those cheap off brands on RA.
  1. coolant temp sensor
    By billyt in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2014, 12:19 PM
  2. coolant temp sensor
    By PaJeff in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2013, 08:10 AM
  3. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. Car won't stay running - Coolant Temp and TPS sensor problem?
    By David A Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2010, 10:37 PM
