Thread: Unknown harness in engine bay
Results 1 to 14 of 14
  1. #1 Unknown harness in engine bay
    Nov 2015
    Tx
    Hi Guys,
    i am changing the heads on my 2006 Grand Prix due to some cracks and while putting everything back together i found this harness laying around and i don't know where it goes.
    The harness has a red label with 1281 on it. Anybody has an idea?
    Thanks a lot and happy thanksgiving day.
  2. #2 Re: Unknown harness in engine bay
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I know there is a harness in the rear of the engine kind of by the alternator that goes to nothing. Is that where you got it from?
  3. #3 Re: Unknown harness in engine bay
    Likely something for a car with cali emissions, for the air pump and stuff.
  4. #4 Re: Unknown harness in engine bay
    being the end of the white plug is real clean looking. it went somewhere.
  5. #5 Re: Unknown harness in engine bay
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    That could've been the end that was plugged in the harness, and the blue end was hanging out?
    Maybe show a better picture of the blue end?
  6. #6 Re: Unknown harness in engine bay
    Nov 2015
    Tx
    I found it right between the radiator fan and the engine (where the AC lines sit).
  7. #7 Re: Unknown harness in engine bay
    hangover park IL
    that plstic tab halfway sticks to the top of the studed bolt holding on the T stat housing (bolt should be in the lower left hole nearest to dogbone bracket
    ~James~ Psychotic Gearhead
  8. #8 Re: Unknown harness in engine bay
    hangover park IL
    coolant temp sensor pigtail
    from plug near injector 3/5 to the collant temp sensor below the T stat housing, harness runs bewteen alum dogbone bracket and T stat neck to keep it off exhaust.
    pretty common for both ends to get unplugged during a teardown.
  9. #9 Re: Unknown harness in engine bay
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Quote Originally Posted by Turbocharged400sbc View Post
    Dang beat me to it
    Sent from my SM-S820L using Tapatalk
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  10. #10 Re: Unknown harness in engine bay
    those plugs look pretty clean to me. when you find a stray plug in the bay its usually filthy dirty looking.
  11. #11 Re: Unknown harness in engine bay
    Nov 2015
    Tx
    Ohhh thank you so much...... i wonder why they had such an adaptor harness like this. Maybe they changed the type of sensor during the years?
  12. #12 Re: Unknown harness in engine bay
    hangover park IL
    Quote Originally Posted by tuononero View Post
    yes, early cars had a 3 wire white connector and 3 wire ECT, then it went to a 2 wire ECT while keeping the 3 wire white connector, eventually replaced by the 2 wire white conn in 03ish+
    and that pigtail is used in a different location on the F body's and other 60*v6 engine harness'.
  13. #13 Re: Unknown harness in engine bay
    the harness on my car is much shorter looking. it goes from the temp sensor to a plug on the top of the lim. it routes under the d/s dog bone.
  14. #14 Re: Unknown harness in engine bay
    Nov 2015
    Tx
    Yeah, that was the one.
    Thank you once again.
  1. Need help! Engine harness 97 GTP
    By Bradh77 in forum General Grand Prix Discussion
    Last Post: 06-10-2015, 05:18 AM
  2. Unknown Part/ 06 Grand Prix/GT/ Engine piece??
    By TekkamanBlade00 in forum Introductions/Noob Questions
    Last Post: 05-06-2015, 08:45 PM
  3. Engine Harness
    By dbextreme in forum General Tech Discussion
    Last Post: 06-20-2012, 04:35 PM
  4. Unknown wiring harness plug
    By Phyrstorm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2011, 06:35 PM
