Thread: Vacuum diagrams from top swapped car
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    Now this raises a question to me. What do I do about the vac line to the EVAP solenoid? Do you reuse the L36 line or do I need to get one when I order the last odds and ends for my L67 top end?
    Also, is that bracket where the MAP sensor mounts on the L36 as well? I know there's a couple brackets back there...
    2009 Subaru Impreza WRX STI
  2. #2 Re: Vacuum diagrams from top swapped car
    Hoffman/Schaumburg, IL
    Quote Originally Posted by Sabrewings View Post
    the L36 map mounts to the end of the UIM.... I reused the Evap vac hose on my setup..... the map bracket is separate from those and bolts to the M90 IIRC
  3. #3 Re: Vacuum diagrams from top swapped car
    Dec 2008
    Roxbury NJ
    Ok, here we go... contacted ZZP and found out their PCM's with the top swap option selected DOES put the BBV tables in the PCM, which means you CAN use the BBV through it. I emailed them again to ask specifically where the wires connect to the PCM harness. Im probably going to go this route, but if I have problems, Im going to disconnect it and let it see atmosphere. Where exactly does the other end hook up for you L67 owners, Where on the BBV do I attach the wire?
  4. #4 Re: Vacuum diagrams from top swapped car
    Dec 2008
    Roxbury NJ
    for anyone wondering, it goes to pin #77 on the CLEAR PCM connector... that is where the BBV wire should be wired to.
  5. #5 Re: Vacuum diagrams from top swapped car
    my evap stuff is still sitting where it was originally on the l36 setup.
  6. #6 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    I know. I see that. My question was if I can reuse the same vacuum line setup.
  7. #7 Re: Vacuum diagrams from top swapped car
    GTP Level Member Scimmia's Avatar
    QCA, IA
    All you have to do is hook it to a vac source, so you should be able to plumb it up however you want. Or eliminate it if you don't have emissions testing.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: Vacuum diagrams from top swapped car
    Barksdale AFB, LA
    I should be able to figure it out then.
  1. Wiring Diagrams and Pinouts available for download here
    By Sinister Performance in forum PCM Tuning
    Last Post: 06-23-2015, 10:30 AM
  2. access to off toppic wiring diagrams
    By Toasty in forum General Tech Discussion
    Last Post: 02-06-2008, 11:15 PM
  3. 2004+ wiring diagrams
    Last Post: 01-14-2008, 01:15 PM
  4. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
