Thread: Plastic runners in the upper intake
Results 1 to 5 of 5
  1. #1 Plastic runners in the upper intake
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey all I know its been forever since I posted anything but I'm curious do I really need to keep those plastic runners in the UIM cause I'd like to remove them but I don't have enough $$ to buy a HV3 insert. Any thoughts? Thanks
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Plastic runners in the upper intake
    Removing them would do you no good.
  3. #3 Re: Plastic runners in the upper intake
    Abilene, Tx
    So its either buy a HV3 insert or leave them alone? No in between?
  4. #4 Re: Plastic runners in the upper intake
    If you trimmed them say ... the same rough height as an HV3...you know what you'd have?
    A cheap HV3
  5. #5 Re: Plastic runners in the upper intake
    Yup.
    DIY HV3.
    Removing them gave a more low end gain for the butt dyno when I did that and hacked out the huge chuck of plastic in the middle of the opening of the manifold behind the TB.
    Sacrificed high end powerband, because the air is just a mess in there at high RPM's with no sort of flow pattern to follow. I'd suggest an HV3 if you can find one used though. Between that and a 3" downpipe (or at the least a u-bend delete and running 91 octane in the car) it'll get rid of all the knock and help the car out quite a bit.
  1. Replies: 33
    Last Post: 05-11-2015, 06:21 PM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  4. Intake Runners?
    By 2001camaroB4C in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-26-2009, 11:33 PM
