Thread: Fixing a dead miss on light load
Results 1 to 7 of 7
  1. #1 Fixing a dead miss on light load
    May 2014
    california
    My Grand Prix has a very noticeable miss, jerk under lite load at 2000 RPM in any gear (manual trans) It feels like plug wires arching. The wires are not neatly routed from the coil pack. Are these wires real touchy regarding proper routing and proper retainers? And if it is wires, What do you recommend? brand?
  2. #2 Re: Fixing a dead miss on light load
    May 2014
    california
    bump! 52 views, no idea?
  3. #3 Re: Fixing a dead miss on light load
    No SES light?
    Why not get new wires and plugs?? Perhaps they are just old and already need to be replaced.
  4. #4 Re: Fixing a dead miss on light load
    Jan 2014
    AR
    I'm curious what year GP, must be 89-96. Stumbling in cruise mode is usually a vacuum leak or weak ignition, in that order and generally speaking. Try neatly routing the plug wires to see if the trouble goes away and maybe you can answer your own question.
  5. #5 Re: Fixing a dead miss on light load
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    If it was factory equipped with a getrag 5-speed, it would have to be a '93 or older. They took that option away from the w-bodies with the interior redesigns in '94.
    As idrivejunk said, a miss under any kind of load is usually either a vacuum leak, or ignition issue. I don't think routing is a factor so long as the right wires/plugs are connected to the right coil pack terminals. If they haven't been done in a while, I'd change out the plugs and wires regardless. If it persists, I know they're a pain in the ass to get to, but I'd pull out the coils and look at them. When I first got my 2-door TGP, it would miss BAD and had 0 power if I went more than 1/4 throttle on it. Drove it like that for a while, and then during one of the local w-body meets, one of the members just happened to look at and noticed that all 3 coil cases were split open like nothing I'd ever seen before. Switched those and the ICM out with new GM take-offs I had picked up on eBay for pretty cheap, and no more problems.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  6. #6 Re: Fixing a dead miss on light load
    May 2014
    california
    Thanks! Its a 1991 with a 5 speed stick, sorry! As an aid in diagnosis, I found a Lumina at the local Pick n Pull with the plug wires laying on the engine. I got the front three and swapped them out in the parking lot. It now runs great but I did order and got new wires, hopefully replaced today or Tuesday. I also got the retainers that hold the wires so I can route and hold them away from the exhaust and fans. Anyone have a recommendation on plugs, I'm thinking A/C Delco rapid fires.
  7. #7 Re: Fixing a dead miss on light load
    Dec 2008
    Naperville, IL
    Good to hear it was a simple fix! Plain old AC Delcos (no Rapidfires needed) or NGKs are more than sufficient. You are not going to gain even .5hp from the plugs, so no reason to splurge on them. Just OEM replacements with decent quality to them.
  1. miss under load?
    By chuckmcclintic in forum General Grand Prix Discussion
    Last Post: 02-11-2012, 10:34 PM
  2. Dead Miss on two cylinders
    By 99regalLSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2010, 07:48 PM
  3. Miss Lisa's GTP is dead
    By Leo Nahlik in forum Introductions/Noob Questions
    Last Post: 08-14-2009, 03:28 PM
  4. 1997 dead miss
    By Hosscat in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:20 PM
  5. Check engine light and horrible miss...
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 07:53 PM
