Thread: 95 GTP 3.4 oil leak and antifreeze leak. Need help
Results 1 to 5 of 5
  1. #1 95 GTP 3.4 oil leak and antifreeze leak. Need help
    Oct 2013
    Princeton,MN
    So I have a 95 grand prix GTP. Never driven in the winter, no rust what so ever so it's worth fixing. It has 160,000 on it. The intake was done. There is still an oil leak and the gasket by the intake was done so im not sure where it's leaking from. There is also an antifreeze leak on the passengers side of the engine. Radiator is new. I am looking to figure out where the common places for the oil leak are, same with the antifreeze leak. Pipe on the passangers side does not seem to be leaking. Any suggestions on how to solve this oil and antifreeze leak?
  2. #2 Re: 95 GTP 3.4 oil leak and antifreeze leak. Need help
    Florida
    as for the oil, these engines are common for the Oring leak just under the tb on the block. it has a plug that was designed to fill the spot for a distributor. the o ring fails and it weeps oil. some people clean it and use RTV but that doesnt last for more then a year. believe me i did it twice. on the third time i was done messing around. I got some QuickSteel epoxi and packed it in there after removing the bolt and cleaning a mating surface. let it cure and its done. I wouldnt use JB weld as it is too runny and could seep down and glue something that shouldnt be. the epoxi fix never leaked again. I had that engine for another 4-5 years before it died and i did my l36 swap.
  3. #3 Re: 95 GTP 3.4 oil leak and antifreeze leak. Need help
    Oct 2013
    Princeton,MN
    Good to know sir, how do I get to the plug? Do I have to take the heads off to fix it or the intake? Any suggestions on the anti freeze leak? The intake was just done a month ago so it wouldn't be leaking there and the water pump and radiator was done recently as well and antifreeze is still leaking on the passengers side.
  4. #4 Re: 95 GTP 3.4 oil leak and antifreeze leak. Need help
    Florida
    sorry had been busy. to get at this plug the Lower intake needs to come off as it is bellow it. some people grind a little bit (1/2 inch) of metal off the head thread boss that is directly above the plug to make more room for it to come up. I took only about 1/4 inch off as i first tried to RTV it. I would get a bunch of shop towels and degreeser to clean it all before you use the epoxi. as for the coolant leak, rent a coolant psi tester and pressurize the system and you might even be able to hear the leak/ hiss.
  5. #5 Re: 95 GTP 3.4 oil leak and antifreeze leak. Need help
    SE Level Member Drifty's Avatar
    Jun 2010
    Fort Worth Texas
    Would this oil leak happen to be worse at start up and drip down off the transmission pan?? I only ask because I'm afraid I am having the same issue.
  1. LIM antifreeze leak
    By 2004GrandPrixGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 10:49 PM
  2. antifreeze leak question
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:37 PM
  3. antifreeze leak
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2011, 08:50 AM
  4. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  5. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
