Thread: whats this noise?
Results 1 to 3 of 3
  1. #1 whats this noise?
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok iknow this is grand prix forums but ive got a 99 montana 3.4 and i thought the power steering was going out,well the power steering pump is were the belt is and this noise is coming from the area around the throttle body and it sounds very similar to the bad power steering pump noise and it only does it when it the vans temp opens up and everything gets hot and down the road but does nothing when first cranked and drove,so what could it be???
  2. #2 Re: whats this noise?
    From where you said the sound is coming from its most likely the trans pump, your trans filter might be plugged so buy a new filter and ~8 quarts of trans fluid and do a pan drop and replace the filter and fluid if the sound goes away then problem fixed.
  3. #3 Re: whats this noise?
    Florida
    just FYI your car/van does not have the 3.4DOHC it has a 3400 ohv. these are very different engines. your engine is more related to the 3100.
  1. Lets play a game, Whats That Noise?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-27-2010, 09:11 AM
  2. Whats this noise???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2010, 12:48 PM
  3. Whats up!
    By whitehead in forum Introductions/Noob Questions
    Last Post: 07-12-2010, 04:55 PM
  4. Replies: 8
    Last Post: 03-11-2010, 07:59 AM
  5. Whats this noise? (Video)
    Last Post: 02-27-2008, 02:05 AM
