Thread: turbo 3.4 dohc with 3400 internals
Results 1 to 13 of 13
  1. #1 Re: turbo 3.4 dohc with 3400 internals
    new britain, ct
    hope it all works out..good luck.
    07 Black GXP.
  2. #2 Re: turbo 3.4 dohc with 3400 internals
    SE Level Member greenmachinegtp's Avatar
    Crossville, TN
    Thanks. I only have one issue. Crank trigger for crank position sensor is way different. Im gonna have to use the 3400 sensor. But its 3 wire and mine is 2 wire. Can I not use one of the wires and it still work? If not I found a solution. http://www.thirdgen.org/techboard/v6...ml?ref=esp-img
    Last edited by greenmachinegtp; 03-12-2012 at 08:39 PM. Reason: To avoid double posts.
  1. Wobble/shake at around 3400 rpm
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2011, 08:47 AM
  2. 3400 uim on a 3100
    By mhartwig in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-08-2010, 01:13 PM
  3. 1997 GTP Internals
    By Hozer1980 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2010, 02:57 PM
  4. Engine swap - 96' 3.4l DOHC out, '93 3.4l DOHC
    By csbrown in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-11-2009, 04:47 PM
  5. anyone with good knowledge of the 3400 DOHC?
    By Reppusmic in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-26-2009, 05:00 PM
