Quote Originally Posted by UR LOSN View Post
do you know if the exhaust smells like coolant? try doing a compression check on it....also. they make a UV kit for coolant leaks. you add it to your cooling system..and they supply you with the light and glasses..
after a few cycles of driving. you can come back and use the light/glasses..and visually check for exterior leaking..just to rule it out.
if it is internal....possibly head gasket. it is a very common thing with the 3.4 DOHC. more than likely it is the rear head as well. you have done nothing wrong.....it happens with age.
thanks! yea its def external, ive had both the intake, and head gaskets replaced. so yea. any idea where i can buy one of these kits??
