Thread: CMP help
Results 1 to 5 of 5
  1. #1 Re: CMP help
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    this problem is kind of different, so i am pretty sure this is why the car will not run? the crank sensor is in the rear of the engine. seem like the harnes would be on the passenger side for that but in the rear.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  2. #2 Re: CMP help
    Klamath Falls, OR
    I was talking to some of the people on 60degreev6 forum and all of them have told me that the 91-93 Grand Prix's with the 3.4L DOHC MFPI do not have a camshaft position sensor because they do not have the 24x crankshaft sensor. So it is not required. The 94-on with the 3.4L SFI systems do have the CMP because they have the 24x crankshaft sensor.
cmp
