Thread: P1640 quad driver error
Results 1 to 2 of 2
  1. #1 P1640 quad driver error
    Snellville, GA.
    My car is a 95 3.4. Hooked up a scanner and it pulled 1 code p1640. What is controled by that quad? I called pontiac dealer and they said it could either be tcc, ac, egr valve, or evap purge valve. I have a new egr valve on it. The problem is when I press the gas too fast it bogs down, like its sputtering. It has a new gas pump, pressure regulator and new coils. My friend said to look at the TPS and MAF. Any help, thanks.
  2. #2 Re: P1640 quad driver error
    MAF or vacuum leak is my bet...anything nowadays with a VC will make it run like a turd. TPS would make it idle very high IMO.
  1. DTC code error
    By carlos Hidalgo in forum General Tech Discussion
    Last Post: 08-11-2009, 08:35 PM
  2. Error code p0740 TCC problem
    By johnd89 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-04-2009, 09:02 AM
  3. Error code po742
    By RichCresci in forum General Tech Discussion
    Last Post: 11-30-2008, 09:37 PM
  4. Vb Garage Upload error
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 10-31-2008, 08:00 PM
  5. Fixing error code P0560
    By dowtrader in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2008, 08:23 AM
