Thread: 2006 gp
Results 1 to 4 of 4
  1. #1 2006 gp
    Nov 2018
    Canada
    Stumped...car randomly completely won't start, no crank, nothing, and the charging system failure light comes on. The car has a battery that is 1 month old. I have a battery tester which shows the battery as good and the alternator as good, I also put a volt meter on the battery and it shows the battery at 14.5 volts while running. What is the most common issue that is causing the no start....please help.
  2. #2 Re: 2006 gp
    bad ground or ground cable come to mind.
  3. #3 Re: 2006 gp
    Nov 2018
    Canada
    Is the ground cable coming off the alternator, or where can I locate it? thanks.
  4. #4 Re: 2006 gp
    off the alt to fuse box is a hot cable.
    follow the neg cable from the battery to the trans bell housing. that bolt can get corroded, or if you see bare cable showing on either end of the cable its likely bad.
  1. 2006 gt trans into a 2006 non gt
    By lilrez in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-29-2017, 05:31 AM
  2. 205/55/r16 on 2006
    By eswtaw in forum General Grand Prix Discussion
    Last Post: 08-06-2014, 01:19 PM
  3. 2006 Gxp.
    By Alsafi92 in forum For Sale - Vehicles
    Last Post: 04-10-2013, 11:18 PM
  4. 2006 pcm? Where are they?
    By chevyy1212 in forum PCM Tuning
    Last Post: 09-08-2012, 04:05 AM
