Thread: Engine takes too long to idle
Results 1 to 20 of 21
  1. #1 Engine takes too long to idle
    Jan 2009
    On This Planet...
    Hi!
    I have a gp 1995 3.1L
    when the engine is cold, it takes a while until the engine idles.
    at start he is at about 1500 rpm for a few minutes, then at around working temp. the rpm is around 900.
    what is the cause for that? is there anything to do to shorten the time to reach 900 rpm?
    (pcm replaced, throttle body cleaned, i guess theres no vacuum leak).
    thank's!
  2. #2 Re: Engine takes too long to idle
    TDCRacing
    Guest
    Sounds normal actually. The pcm commands a higher idle speed during startup. Especially when it's cold it's going to command a high idle to try to reach operating temps sooner.
    And the 900 at idle seems to be about right for an automatic.
  3. #3 Re: Engine takes too long to idle
    Jan 2009
    On This Planet...
    The problem is that the ambient temp is not so cold...
    and a couple of months ago it worked perfect. a few seconds at 1500 rpm and then dropped to 900. now it's a matter of minutes.
    the main problem with this rpm is that the tranny knocks when shifting into gear.
    could it be the temp. unit that goes to the computer?
    IAC?
    any solution?
  4. #4 Re: Engine takes too long to idle
    TDCRacing
    Guest
    I see. Well how is you're temp gauge on the dash working? They should be the same sensor.
    It could be a dirty IAC, Try taking it off and cleaning it with some carb cleaner or something like that.
  5. #5 Re: Engine takes too long to idle
    Jan 2009
    On This Planet...
    the dash gauge is o.k.
    the entire throttle body has been thoroughly cleaned about a month ago.
    i have heard there is some kind of step motor around there. could it be it?
    thanks!
  6. #6 Re: Engine takes too long to idle
    TDCRacing
    Guest
    Right the Iac is measured by steps. I think usually when they go bad they do just the opposite. But it may be worth taking off and cleaning the inside of it. Where the air comes out.
    Maybe also spray around the intake with some carb cleaner to check for vac leaks. And all the other usual places. The IAC on the later year cars have an o-ring to seal it. So maybe that would also be worth checking out too.
  7. #7 Re: Engine takes too long to idle
    Jan 2009
    On This Planet...
    thanks! I`ll check it out.
  8. #8 Re: Engine takes too long to idle
    TDCRacing
    Guest
    Let us know and we'll go from there.
  9. #9 Re: Engine takes too long to idle
    Jan 2009
    On This Planet...
    OK guys!
    it seems like the problem is now resolved!!!
    first- i took the entire throttle body apart. cleaned everything thoroughly.
    especially the IAC which was dirty as hell.
    second- I've replaced the thermostat, which looks to me like it never been replaced since the car went out from Detroit... (approx. 14 yrs.)
    third- I've added the BG ATC (Automatic Transmission Conditioner).
    now everything seems working just fine! the idle is reached very quickly, the car has returned some horses to the engine, and the tranny won't knock! the gears are shifted very softly.
    bottom line- I'm H A P P Y ! ! !
    Thanks!
  10. #10 Re: Engine takes too long to idle
    Pocatello, Id
    woudl this also cause a 94 to bounce its revs at start up and idle there after, but also drive down the road ok? i just got this car, and love it already, but its hard to start, have to gas it to start, and then the revs bouce once it will sustain itself
  11. #11 Re: Engine takes too long to idle
    Banned - Busted For Scamming
    Feb 2009
    yea, check it IAC
  12. #12 Re: Engine takes too long to idle
    SE Level Member 94gpseFangsRide's Avatar
    Idaho
    ok my account, capnfangsgp wont let me in.. so i made this one.. thank you ill clean up the whole intake.
  13. #13 Re: Engine takes too long to idle
    Idaho
    can someone post a pi of where tha iac is on a 94 with the mpfi engine?
  14. #14 Re: Engine takes too long to idle
    Idaho
    alright cleaning the throttle body and the iac fixed the idle being too high, at 1000 rpms is ok for now, and im not sure what but somehow i fixed a vaccum leak i had and also did something to fix that surge b4 i cleaned anything.. but thanks guys for the great help now i have time to make my welcoming post for myself!
  15. #15 Re: Engine takes too long to idle
    Idaho
    a lil random but is the beretta also a w body car? just wondering about it cuz my gf has a beretta z26
    CapnFang
    !994 Grand Prix se 3.1v6 mpi stock now.
    PLanned mods are either forced induction, s/c'd 3800 from bonneville ssei with intercooler, or even the daring idea of a 4.3l v6 or a small v8 rwd conversion.
  16. #16 Re: Engine takes too long to idle
    Quote Originally Posted by 94gpseFangsRide View Post
    I think the Beretta is a J-Body...like the Cavalier.
  17. #17 Re: Engine takes too long to idle
    Idaho
    you sure? its bigger, and better built. plus most cavi's were 4 cylinders.. ill try to find out but yeah thanks!
    CapnFang
  18. #18 Re: Engine takes too long to idle
    Most Beretta's were too...the only V6 were the Z26 or whatever.
    And it is a L-Body.
  19. #19 Re: Engine takes too long to idle
    Idaho
    my aunts when i was a kid wa a v6 auto and hers was plain jane. lots of plain janes berettas were v6... iv known at least 6 ppl who have ownd them.
    CapnFang
  20. #20 Re: Engine takes too long to idle
    My bad. Not a Beretta expert.
  1. Stumble at idle
    By lowdeuce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2008, 10:26 PM
  2. stalling and bad idle.....
    By kingd44 in forum General Tech Discussion
    Last Post: 10-09-2008, 07:27 PM
  3. Idle issues.
    By TDCRacing in forum General Tech Discussion
    Last Post: 09-02-2008, 11:43 AM
  4. idle issues.
    By TDCRacing in forum PCM Tuning
    Last Post: 09-01-2008, 02:21 PM
  5. What takes longer? Heads/Cam or Engine Swap?
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 06:38 AM
