Problem seems to be solved. Definitely an airflow problem. I went digging around looking for phantom leaks that might be introducing air into the system and found the front of the radiator caked with a 1/2" of crud. A good pressure washing and the car barely tops 185 in 100 degree temps and stop and go traffic. AC seems to be running a couple of degrees cooler as well. Fingers cross it was that easy.
