Thread: Got ****ed in the ass by my Dad
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 104
  1. #81 Re: Got ****ed around on a craigslist deal please help
    Exactly...
    If we think about an engine and where items are under pressure, oil will almost never get into coolant. Oil is under pressure from the pump, through filter, bearings, lifters and pushed up into pushrods. After that.. it's drips back to the pan, and has zero pressure. Oil does not enter the heads under pressure.
    Coolant meanwhile flows through the heads, block, headgasket area, LIM, Alt bracket, timing cover, WP, hoses, heater core and radiator under 16lbs of pressure constantly.The chances of oil having more pressure in an area where it could potentially meet coolant ... doesn't exist.
  2. #82 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    Unless you have a cracked head or cracked engine block
    Sent from my SM-G900P using Tapatalk
  3. #83 Re: Got ****ed around on a craigslist deal please help
    not even then sir. its pretty much impossible like were are saying.
  4. #84 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    Well hopefully it's just sludge
  5. #85 Re: Got ****ed around on a craigslist deal please help
    it is, the deg sludge is slick as sh it. and leaves a brown slime behind on your fingers.
  6. #86 Re: Got ****ed around on a craigslist deal please help
    May 2014
    Flint
    And I know it's supposed to cause permanent damage.... But other than Temps what can it harm my temperatures are fine
  7. #87 Re: Got ****ed around on a craigslist deal please help
    that coolant dont eat gaskets, it just dont like to have air in the cooling system. when air meets dex cool it sludges up, then it can turn to snot and clog cooling ports. i pulled some nice blocking size balls of dex snot out of my heads when i did my lim.
    just flush it and carry on, use a flush like prestone to clean it out good inside the block and rad.
  8. #88 Re: Got ****ed over by my Dad
    BTW.. I changed your title for ya. It felt more appropriate.
  9. #89 Re: Got ****ed over by my Dad
    lmao.......
  10. #90 Re: Got ****ed over by my Dad
    Mar 2015
    Lumberport, WV
    I know it's been a while since this was active but I thought I would just share this. I only paid $550 for my 2000 GP SE. I hate the fact that it's only a 3.1 but in 2000 they gained a little HP over the pre 2000 models. My engine only has 45,600 miles on it and I have no engine issues, other than loosing a tiny bit of oil. Not sure where its going but I changed the oil at 43,000 miles and here I am 2,600 miles later and I've only about an 8th of a quart of oil. I really like my 3100. I do have transmission issues, but that's not related to the type of engine, lol
  11. #91 Re: Got ****ed over by my Dad
    Apr 2015
    Columbus, OH
    Quote Originally Posted by scheuvront1993 View Post
    Wait... You have less than a quart of oil left in the engine? If I misunderstood you, look around the valve covers. That's where it all started for me. First a simple valve cover gasket repair, a week later a lim gasket job, two months later a top swap.
    Maybe next car I'll just keep adding oil...
    Top Swapped 01 Imp
  12. #92 Re: Got ****ed over by my Dad
    GTP Level Member
    Aug 2012
    st louis park, MN
    I know it's been a while since this was active but I thought I would just share this. I only paid $550 for my 2000 GP SE. I hate the fact that it's only a 3.1 but in 2000 they gained a little HP over the pre 2000 models. My engine only has 45,600 miles on it and I have no engine issues, other than loosing a tiny bit of oil. Not sure where its going but I changed the oil at 43,000 miles and here I am 2,600 miles later and I've LOST only about an 8th of a quart of oil. I really like my 3100. I do have transmission issues, but that's not related to the type of engine, lol
    Quote Originally Posted by bandook View Post
    I'm guessing he meant lost...
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  13. #93 Re: Got ****ed over by my Dad
    Apr 2015
    Columbus, OH
    Quote Originally Posted by stocker View Post
    That's why I said "if I misunderstood you"...
    Top Swapped 01 Imp
  14. #94 Re: Got ****ed over by my Dad
    Mar 2015
    Lumberport, WV
    I apologize, I just now saw this, lol. I did mean lost. And I actually just changed the oil again at about 48,000 miles, I'm at almost 51,000 now and I've not lost a drop of oil since.
  15. #95 Re: Got ****ed in the ass by my Dad
    Enfield, CT
    I would just upgrade to a 3800
    Sent from my LG G3
  16. #96 Re: Got ****ed in the ass by my Dad
    Aug 2012
    Stonington, CT
    I have a 2001 SE and have been through the LIM gasket leakage issue. I agree with what others say about what looks like oil in the coolant actually being DEX coolant sludge. It tends to accumulate in the coolant overflow tank. It was present when I got the car, and the car at that point was not using any oil or coolant excessively, nor was there any evidence of coolant in the oil (the dipstick oil will look like slimy chocolate milk if there indeed was coolant in the oil).
    After a year or two, the engine started losing coolant, at first slowly, then a LOT. It was due to the infamous lower intake manifold gasket leak that plagues the 3.1 V6s. Fortunately, the leak was from the coolant system to outside the engine, not internally to the engine oil or cylinders. It first started out as a slow drop in coolant over weeks at a time, along with the smell of anitfreeze under the hood. Eventually it got bad enough that i could see the leak out of the engine from around the LIM gasket edge on the head above the starter motor. At that point I was going through about a quart of coolant every week and the antifreeze smell under the hood was extremely strong. I had the LIM gaskets replaced about a year ago and since then, the engine has run really well, with no more coolant loss at all and of course the antifreeze smell is gone. There is still some sludge in the coolant overflow tank, I probably should take it out and clean it, the DEX cololant is pretty clean after the LIM gasket replacement.
    I would keep an eye on your engines oil and coolant levels after your flush. You may not have an LIM gasket leak at all. If you do see coolant showing up in the oil, take care of it right away. I had a Ford 3 liter V-6 develop a LIM gasket leak (not just GM engines had this problem in the late 90s early 2000s) that did put coolant in the oil and before I could have it taken care of, it DID spin a bearing.
    All that said, as a father of two now adult sons, you need to show your father more respect. Starting off a thread with a title like you used would really piss me off if I knew it came from one of my sons, especially after I tried to help him out in buying a car. Also doesn't make much of a good first impression of you to people who don't know you such as readers of this forum like me.
  17. #97 Re: Got ****ed in the ass by my Dad
    The title of this thread is so Arkansas on so many levels
  18. #98 Re: Got ****ed in the ass by my Dad
    Jan 2014
    AR
    Quote Originally Posted by blueguy View Post
    The title of this thread is so Connecticut on so many levels
    Fixed it for ya
  19. #99 Re: Got ****ed in the ass by my Dad
    I came in here for the gangbang.
  20. #100 Re: Got ****ed in the ass by my Dad
    Enfield, CT
    Quote Originally Posted by idrivejunk View Post
    Fixed it for ya
    Just out of curiousity, why Connecticut?
    Sent from my LG G3
