Thread: Oil Change on a 3.1L V6
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Oil Change on a 3.1L V6
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Last time I used the e brake in my dads car it broke in the cable and got jammed on so I just unhooked it and never missed it. So I don't trust them anymore
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  2. #22 Re: Oil Change on a 3.1L V6
    thats just dumb thinking. if they work they work, if they dont fix them.
    stuff gets old rusts and breaks. fix the cable.
    also a unused e brake will break before one thats used every now and then. if you use it here and there, you'll know if its working or starting to fail some how. dont use it and then need it and surprise, no brake, locked up or dragging e brake, see where i m going ?
  3. #23 Re: Oil Change on a 3.1L V6
    SWPA
    I use my ebrake even when parking in my flat driveway. I just don't like the car sitting on the park prawl.
  4. #24 Re: Oil Change on a 3.1L V6
    i park in the same spot for like 4 years now, as i back into my spot it put it neutral and it rolls into its 4 holes its made over time. then i toss it in park.
    i also have a window behind my car, so when the pass side reverse light is 1/2 way gone in the rear view, im squarely in my spot too.
  5. #25 Re: Oil Change on a 3.1L V6
    Feb 2010
    Chatsworth, CA
    I was wondering if using my jack stands will bend/damage the pinch welds?
    http://www.northerntool.com/images/p...AA3FFC&01NA=na
  6. #26 Re: Oil Change on a 3.1L V6
    Apr 2012
    Dayton, OH
    Just put them on the subframe it will be fine, that's what I do
    2012 F150 STX
  7. #27 Re: Oil Change on a 3.1L V6
    if your rockers are rusty dont use them, always look for solid steel. the frame where the lower control arms bolt on is a perfect bar to use.
  8. #28 Re: Oil Change on a 3.1L V6
    Feb 2010
    Chatsworth, CA
    Can I also just jack my car up unto my rhino ramps?
  9. #29 Re: Oil Change on a 3.1L V6
    why not drive the car up them and call it a day?
    ive never used jack stands for a oil change, always use the ramps. my trucks were nice. slide under drop the pan bolt. ground clearance what a concept.
  10. #30 Re: Oil Change on a 3.1L V6
    Feb 2010
    Chatsworth, CA
    I tried it once and they went under my car
  11. #31 Re: Oil Change on a 3.1L V6
    clamp or bolt a 2x4 to the end so it acts like a wheel stop, or have some one guide you.
  1. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  2. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
