I just had to curb my '93 GP SE because of some overheating issues. Took it up the street and paid a good chunk to be told it was my lower intake manifold gasket going bad and my radiator has to be replaced. I was quoted at 6-8 hours of labor.
I've done my research and figured if it is in fact the gasket going, unless I do it myself it may not be worth it. Especially knowing it could also be a head gasket issue.
Sitting in park it does idle a bit rough. It holds coolant but leaks slowly. I was recently told the prior owner topped up with DEXCOOL. It was run after this. The leak doesn't appear to be from around the engine, it seems to be around the radiator and hoses, however it doesn't really leak until it's hot. There doesn't seem to be coolant in the oil (yet). If I start it cold, it takes less than 10 minutes to run hot. The thermostat looks fairly new. The mechanic that diagnosed it explained to me he drained and refilled the coolant system. I'm a bit lost given I'm not mechanically challenged but I'm also not an expert.
Does it sound like a LIM gasket or something a flush or a new radiator would help?
Sent from my DROID3 using Tapatalk 2
