Thread: Bubbles in coolant???
Results 1 to 11 of 11
  1. #1 Re: Bubbles in coolant???
    Could be the intake gasket going bad and it's low on coolant.
  2. #2 Re: Bubbles in coolant???
    May 2013
    Michigan
    Well I spoke with a mechanic friend of mine. He says its most likely the head gasket or the lower intake manifold gasket. There is no coolant in the oil or the other way around. A large amount of pressure builds up in the coolant system.d
  3. #3 Re: Bubbles in coolant???
    Dan, How's a LIM gasket issue possible to cause bubbles?
  1. Is it normal to have bubbles on the transmission dipstick?
    By Coldwaves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2013, 10:16 PM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. Small bubbles in trans fluid
    By Gasnmyveins in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2011, 11:27 PM
  4. Rust Bubbles
    By ljmonnin12 in forum Visual/Body Modifications
    Last Post: 03-08-2011, 01:47 AM
  5. Bubbles in coolant/ radiator
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 12:27 PM
