Thread: Intake system, plenum, throttle body
Results 1 to 20 of 25
  1. #1 Intake system, plenum, throttle body
    SE Level Member Badgers4life's Avatar
    Mar 2013
    I have put in a larger tb and a custom CAI with a k&n performance filter , and I want to know what would happen if I increased the upper intake plenum to a larger size such as the 3400. It will be bigger, and my thoughts are that it will slightly take away low end torque (not much), but I will see more "boost" so to speak at wot. Is this true??? I feel like bringing in more air in those 3 different sections will be a benefit in all.
  2. #2 Re: Intake system, plenum, throttle body
    what year are you working with?
    SMGPFC Member #10
  3. #3 Re: Intake system, plenum, throttle body
    Mar 2013
    It is a 2003 3.1. Ive done upgrades on tb, ca,i plugs, wires
  4. #4 Re: Intake system, plenum, throttle body
    what tb? and your motor already has the 3400 manifolds on it
    SMGPFC Member #10
  5. #5 Re: Intake system, plenum, throttle body
    Omaha, NE
    You have an upper intake plenum and boost? ...On a 3100????
    +36?
  6. #6 Re: Intake system, plenum, throttle body
    Mar 2013
    I have not yet put the 3400 upper intake on yet. It currently has the stock 3100s
  7. #7 Re: Intake system, plenum, throttle body
    it already has 3400 intakes on it dont buy them again
    SMGPFC Member #10
  8. #8 Re: Intake system, plenum, throttle body
    Mar 2013
    even if its the straight stock 3100? that doesnt make sense.. The 3400 has the same set up but just larger parts to it. Thats why i went with the 3400 tb because it gave me a wider port.
  9. #9 Re: Intake system, plenum, throttle body
    the tb are different the 3400 tb is 4m bigger then the 3100 but the manifolds are the same, in 2000 or 2001 cant remember GM changed it and they all got the same intake manifolds
    SMGPFC Member #10
  10. #10 Re: Intake system, plenum, throttle body
    Mar 2013
    Dang for real?
  11. #11 Re: Intake system, plenum, throttle body
    yup, your best bet is to get p&p intakes and headers..but with you got the bank roll drop a turbo in it
    SMGPFC Member #10
  12. #12 Re: Intake system, plenum, throttle body
    Mar 2013
    where would i get those?
  13. #13 Re: Intake system, plenum, throttle body
    Omaha, NE
    P&P = Ported and Polished.
  14. #14 Re: Intake system, plenum, throttle body
    Milzy Motorsports
    WOT-Tech
    i like milzy better but ive dealt with them more
    SMGPFC Member #10
  15. #15 Re: Intake system, plenum, throttle body
    Mar 2013
    Yea i guess so. Thanks for the advice
  16. #16 Re: Intake system, plenum, throttle body
    Mar 2013
    Another question for ya... If I get a 3" downpipe for my 3100, from a 3800, will it fit? on ebay they have small chopped downpipes that end before the cat, so they are relatively cheap. They have the 2 hole "oval" bolt on set up. I dont really see a difference, but maybe you guys can tell me if it would work or what I would have to do to make it work.
  17. #17 Re: Intake system, plenum, throttle body
    i dont think so, you can get a 3100/3400 dp or you can just get headers
    SMGPFC Member #10
  18. #18 Re: Intake system, plenum, throttle body
    Mar 2013
    What do you think would be the best option? The milzy motorsports website has headers and a downpipe. The downpipe is like 199.99 and the headers I think are 299.99
  19. #19 Re: Intake system, plenum, throttle body
    they dont offer headers for a w-body, an n-body yes. Pacesetter makes a set for the w-body 31/3400 and with headers you get a dp
    SMGPFC Member #10
  20. #20 Re: Intake system, plenum, throttle body
    Mar 2013
    What is the flange dimensions for the exhaust pipe that attaches to the manifold. I want to get a larger downpipe like a 2.5" but I dont know where to get one that fits. I cant find any info on ones that will fit my car... I really just want the first foot of down pipe that attaches to the manifold and then I can weld and attach whatever piping I need from there.. But getting that 2.5" downpipe is becoming a pain in the a**..
  1. 2008 Grand Prix GXP air intake/Throttle body spacer
    By mallard22 in forum 5.3L V8 (LS4)
    Last Post: 08-15-2011, 05:45 PM
  2. Throttle body intake questions
    By Dobbs122 in forum General Tech Discussion
    Last Post: 08-01-2011, 11:40 PM
  3. Intake plenum gasket
    By JAllegar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2009, 10:09 PM
