Thread: Another Car wont start thread...
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Another Car wont start thread...
    Feb 2013
    Idaho
    So My car was running fine drove it to work. go off work tried to start the car, it starts up then immediately dies. Continue to try and start it, does turn over and everything seems to work fine but wont start. So gas was low, its a new to me car so I thought maby I ran it out of gas. Put gas in it, still nothing, just cranks. I really need this car for work lol any ideas? or where to start?
  2. #2 Re: Another Car wont start thread...
    Unplug the MAF sensor and try again.
  3. #3 Re: Another Car wont start thread...
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    So many possibilities. Do you hear your fuel pump?
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  4. #4 Re: Another Car wont start thread...
    Start with maf, then tell us what you are driving, because "another car" doesn't really help much.
  5. #5 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    Sure sorry about that. Its a 93 grand prix . 3.1 se. So i m not sure if I found the maf sensor or not. I'm sure I found the tps but everything that looked like a maf sensor in photos didn't seem to match anything I could see around the intake.
    Sent from my SGH-I897 using Tapatalk 2
  6. #6 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    I cant tell if there is sound coming from the fuel pump, and I don't have anyone around to help with it unfortunately. I guess I should check fuel pump fuse, relay and possibly try starting fluid in the intake?
  7. #7 Re: Another Car wont start thread...
    Ok..in the tube between the throttle body and the airbox is the maf sensor. It'll have three wires going to it. The air intake temp sensor has two wires.
    Yeah..you can check by using some flammable something in the intake. It's not like you can reach your fuel pressure schrader on that motor.
  8. #8 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    So if this photo shows up there is no plug or anything with 3 wires only 2 wires. I sprayed some carb cleaner in the intake and it didn't start so mabey not fuel system?
  9. #9 Re: Another Car wont start thread...
    Feb 2013
    Idaho
  10. #10 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    I swapped out the fuel relay and checked all the fuses and all seems ok. It does look like the pressure valve is accessable on the pass side. Should that be the next step?
  11. #11 Re: Another Car wont start thread...
    Nebraska
    Those EGRs on the older 3.1 are a pain in my ass, Ive had only grief with them. I dont think the EGR is your problem, even if its stuck closed or open it should still start. Have you checked for spark?
  12. #12 Re: Another Car wont start thread...
    Nebraska
    Pre 94 do not have MAF, Id have someone listen for fuel pump when you turn the key to run position. Have you checked fuel pressure? spark? any thrown codes? OBD 1 i think there a paperclip trick u can do.
  13. #13 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    It was giving 3 codes for exhaust recirulation 71 72 73 I think. Which was the 3 solenoids. Egr valve I think
  14. #14 Re: Another Car wont start thread...
    Nebraska
    Take a spark plug out and with the wire connected ground the side of it on the block or metal and you should see an arc.
  15. #15 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    No how would I go about that?
  16. #16 Re: Another Car wont start thread...
    Glad 94 hopped in. I was about to say, I don't see a maf either.
  17. #17 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    How could one do that with only 1 person? Lol sorry I'm very limited
  18. #18 Re: Another Car wont start thread...
    You don't. YOu get a second person.
    We assume you have at least one friend willing to zap you.
  19. #19 Re: Another Car wont start thread...
    they do sell a spark tester thing, you put it in the plug wire and if it flashes its getting spark.
    or you can try to rest the spark plugs electrode on metal somewhere on the engine where you can see it while cranking the engine. once again if you see it sparking, blue spark is best, your good.
  20. #20 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    Spark result
    https://www.youtube.com/watch?v=3YlE...e_gdata_player
  1. 04 gtp wont start
    By BlackCompg04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2012, 08:53 AM
  2. 97 GP GT wont start, need some help
    By armyguy1027 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2012, 03:33 PM
  3. Help help gtp wont start
    By GTPWINDYCITYBOI85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2012, 10:12 PM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
