Thread: Another Car wont start thread...
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
  1. #1 Re: Another Car wont start thread...
    check the fuse box for a blown fuse, if they are all good, then when you drop the tank, you can test for power at the plug for the pump to make sure its getting power.
    if you have power, the pump is dead.
  2. #2 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    Is there a write up on dropping the tank and proper jack stand placement and such? Also is there a way to test power to the pump before dropping the tank
  3. #3 Re: Another Car wont start thread...
    the plug is on top of the tank, so you need to drop the tank and reach to the top and unhook it all. good time to see if the tank is rusty inside too.
    google turned this up I need a new fuel pump in my 94 grand prix...? - Yahoo! Answers
  4. #4 Re: Another Car wont start thread...
    Feb 2013
    Idaho
    So after a couple hours and a big pain in the ass the got replaced and it starts! 1 issue... The idle is crazy high now. Was not before the pump went out. It idles at 2500
    Sent from my SGH-I897 using Tapatalk 2
  5. #5 Re: Another Car wont start thread...
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    Just incase someone runs across this and it doesn't help..... Another reason why our cars would start then turn off seconds later that i know of is the passlock system we have (if equipped*). The key has a value programed into it, the car has two values it remembers and the key has to be in between to be able to start the car. You would run across this when installing a remote start, and requires a bypass module to trick the car into thinking the key is in using the canbuss wires. So i can imagine a key can get damaged and give you the same problems.
  1. 04 gtp wont start
    By BlackCompg04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2012, 08:53 AM
  2. 97 GP GT wont start, need some help
    By armyguy1027 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2012, 03:33 PM
  3. Help help gtp wont start
    By GTPWINDYCITYBOI85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2012, 10:12 PM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
