Thread: noise after head gaskets and lim
Results 1 to 14 of 14
  1. #1 noise after head gaskets and lim
    SE Level Member jpe's Avatar
    Jul 2011
    WI
    anyone have any idea what this noise is or what could be causing it? it started after i did head gaskets and lim gaskets. thanks
    2012-09-21_18-27-52_881_zpsd1c773e0.mp4 video by emkowjp - Photobucket
    08 gt mustang
    87 t top resto in progress
    01 gt grand prix (sold)
    01 se grand prix
  2. #2 Re: noise after head gaskets and lim
    Mar 2012
    NC
    All my speakers seem to be playing is a high pitched noise. Is that what you're referring to?
  3. #3 Re: noise after head gaskets and lim
    Jul 2011
    WI
    yeah thats pretty much the noise. it doesnt sound like a vacuum leak to me but i cant really pinpoint where its coming from.
    08 gt mustang
    01 se grand prix
  4. #4 Re: noise after head gaskets and lim
    Mar 2012
    NC
    It kinda does sound like a shifted gasket, but the engine is running pretty smooth from what I can tell. Break out the carb clean and spray around. If it's a vacuum leak, you'll find it.
  5. #5 Re: noise after head gaskets and lim
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    ^ This
    It does kinda sound like a vacuum leak though.
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  6. #6 Re: noise after head gaskets and lim
    Jul 2011
    WI
    ok i can try that but i dont think it does it until its warmed up. the car runs perfectly just has that squeal and do the rockers/lifters sound a little noisy? thanks again for the replies
    08 gt mustang
    01 se grand prix
  7. #7 Re: noise after head gaskets and lim
    Mar 2012
    NC
    Those lifters always sound noisy after LIM gaskets.
  8. #8 Re: noise after head gaskets and lim
    Jul 2011
    WI
    also i dont have any carb cleaner just starting fluid will that work?
    08 gt mustang
    01 se grand prix
  9. #9 Re: noise after head gaskets and lim
    Mar 2012
    NC
    Not preferred, but it might work. Got brake kleen?
  10. #10 Re: noise after head gaskets and lim
    Jul 2011
    WI
    i have brake cleaner but not sure what brand it is. also it idles perfectly and if i pull off a vacuum line it idles like crap.
    08 gt mustang
    01 se grand prix
  11. #11 Re: noise after head gaskets and lim
    HUDSON
    No question about it, that IS a vacuum leak. Sounds like an F-16 sitting on the tarmak!
  12. #12 Re: noise after head gaskets and lim
    Jul 2011
    WI
    where are the most common areas to leak? could it be the upper intake? thanks
    08 gt mustang
    01 se grand prix
  13. #13 Re: noise after head gaskets and lim
    See if pulling your oil cap off makes a difference. Try tightening the upper intake manifold with the car running and see if that helps. If those don't help pull the belt off and start it and see if it helps.
  14. #14 Re: noise after head gaskets and lim
    It's a 3100...trust us..that's a vacuum leak. Check the stupid connections at the top of the TB. Those are super easy to have leak.
    (Did anyone else have the vid open and think to themselves. I see the problem...it's a 3100. then the vid played.)
  1. $$$$$$ 4 Head gaskets
    By Octane in forum Engine
    Last Post: 01-06-2011, 12:54 AM
  2. Copper Head Gaskets
    By bigdawg15005 in forum General Tech Discussion
    Last Post: 10-15-2009, 08:34 PM
  3. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
  4. cylinder head gaskets
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2008, 09:33 AM
  5. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
