Thread: Troubleshooting Power Antenna?
Results 1 to 5 of 5
  1. #1 Troubleshooting Power Antenna?
    Mar 2014
    michigan
    Aftermarket radio and the power antenna doesn't raise. Is it supposed to raise when you turn on the ignition? Or is it tied into the radio? Or both? I read a write up about trouble shooting it and taking it out of the trunk and I guess seeing if the motor runs on it or something to that effect? Do these things commonly fail? This seems like a pretty straight forward walk-thru:
    Code:
    http://www.familyhandyman.com/automotive/how-to-fix-a-car-power-antenna/view-all
    or are there other things I wanna look at first?
    Thanks for any help.
  2. #2 Re: Troubleshooting Power Antenna?
    re read your installation directions, theres a wire for the power antenna in the cars harness. it needs to be told to go up.
    most radios will have a wire labeled power antenna.
  3. #3 Re: Troubleshooting Power Antenna?
    Mar 2014
    michigan
    LOL I didn't do the install but I thought about what if its not hooked up to the radio. I'll pull off the dash and take a look as soon as its warm enough here.
  4. #4 Re: Troubleshooting Power Antenna?
    i figured you just installed it lol
    im sure you could run a toggle switch to the antenna wire to power it.
    you could also check for power at the antennas plug. maybe its got power but its just not working. and check the fuse box, there maybe a blown fuse for it.
  5. #5 Re: Troubleshooting Power Antenna?
    Mar 2014
    michigan
    Oh yeah fuse I didn't think about those either.
  1. Power antenna on 97 grand prix
    By jteske88 in forum Audio, Security & Visual Electronics
    Last Post: 08-23-2011, 11:17 PM
  2. power antenna
    By Jay 88IROC in forum Audio, Security & Visual Electronics
    Last Post: 05-21-2011, 04:48 PM
  3. 2004 Grand Prix Antenna Power Wire
    By cgiversen in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2010, 01:13 AM
