Thread: AC delco platinums
Results 1 to 12 of 12
  1. #1 AC delco platinums
    Sep 2011
    Southern Alberta, Canada
    Ok i know there are several threads about spark plugs, but could find one with these plugs
    AC delco 41-940 copper platniums
    The engine runs great, the gap is 0.060 and they look good.
    Should i change or leave? Dont know how old these are.
    And is anybody against Accel wires??
    Part Number: 41-940
    Weight: 0.1 lbs
    Hex Size: 5/8 in.
    Thread Size: 14 mm.
    Electrode Core: Copper
    Resistor: 0.9-5 - 220
    Heat Range: 4
    Electrode Tip: Platinum
    Insulator Type: Smooth
    Seat Size: 14 mm.
    Rib Configuration: Ribless
    Thread Reach: 0.679 in. (17.25 mm.)
    Terminal top fixed or threaded: Fixed
    Seat Type: Tapered
    Shell Type: Nickel plated
  2. #2 Re: AC delco platinums
    Pennsylvania
    IF you gapped them with that gapping coin-a-ma-bobby, they may be borked.
  3. #3 Re: AC delco platinums
    Sep 2011
    Quote Originally Posted by SlowNA06 View Post
    no just checked the gap.
  4. #4 Re: AC delco platinums
    I'd change them just for piece of mind knowing when they were changed last. I used accel wires on my el camino and really liked them but I don't know about on the gp's
  5. #5 Re: AC delco platinums
    i had those when i got the car and changed them out for ngk gold's(on sale super cheap)
    also changed the wires to what you listed.
    still runs just fine
    SMGPFC Member #10
  6. #6 Re: AC delco platinums
    For what it takes to change them on a 3.1. If you have them out. I wouldn't be taking chances of putting an older plug back in.
  7. #7 Re: AC delco platinums
    Sep 2011
    I only had one out, and im looking for new plugs now, just deciding which ones i want.
  8. #8 Re: AC delco platinums
    Good luck..I'd suggest storing some spare blood with the Red Cross for once you finish up.
  9. #9 Re: AC delco platinums
    Sep 2011
    why, ive already changed the O2 sensor, cant be much harder, can it?
  10. #10 Re: AC delco platinums
    Pennsylvania
    Well, the plugs are hidden behind the exhaust manifolds. Which are hidden behind razor sharp heat shields and the rear barely has enough room to get an arm down the hole. You'll be fine.
  11. #11 Re: AC delco platinums
    It's possible, not even horrible, but they are tougher than our 3.8L version of the car.
  12. #12 Re: AC delco platinums
    Sep 2011
    I guess ill have to wear my napa mechanics gloves
  1. Which is the best AC DELCO Wire Set
    By 71gs3504sp in forum General Tech Discussion
    Last Post: 12-30-2011, 04:35 PM
  2. AC Delco Explosion
    By Blacknight02GT in forum Off Topic Discussion
    Last Post: 04-04-2009, 08:00 PM
  3. AC Delco plugs
    By jak2908 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2008, 03:08 PM
  4. Pntiac delco???
    By TMOTA503 in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2008, 09:49 AM
