Hello,
I have a 1997 grand prix with a 3.1 in it, and the fuel level gauge reads full and the low fuel light is on all the time.
I have checked continuity on the black and white wire from the sending unit back to the pcm and it was fine (.5 ohms).
the weird thing is that on the purple (5v) wire it is reading 2.7 v all the time (should it not read 5v all the time)?. I have tried robbing 5v's from the tps to run back to the sending unit and nothing changed. I have tried to ground out the purple wire and still have not had a change in the fuel gauge. I have tried to bypass the sending unit and jumped the purple wire to black and white and still no change.
Should i not be able to get the fuel gauge to move one way or the other if i ground out the purple wire? should i not be able to get the gauge to move if I apply 5v to the black and white wire?
I am a little confused, i have seen one diagram online that shows the black and white coming back to the pcm and joining with a couple of other straight blacks and going into the pcm. Should the black and white wire not go back to the pcm seperately to measure the voltage drop across the fuel level sensor?
Any help or input would be greatly appreciated as this is driving me nuts![]()
