Hey everyone, i recently acquired a 1990 Grand Prix SE with the 3.1 V6 that i got from my boss which will be helping me fix this up. It has sat for 4 years and has been started periodically throughout those 4 years but now wont start leading me to my questions... First is the fuel pump will not come on i checked the fuses for it (Fuel pump ECM and Relay) and both are good but i found this wire hanging that comes out from the bottom of the Fuel pump ECM/Relay box (see picture below). Is there anyway to test the fuel pump without dropping the gas tank? Now my Second question is when i go underneath and use a screw driver on the starter solenoid it will turn over just fine but when i try to turn it over using the ignition all i hear is the starter clicking... I cleaned the terminal on the starter and obviously the starter is fine so any ideas on what it could be? I will have many more questions but first i need to figure out whether i need to replace the fuel pump or not. Thank you in advance for any input or suggestions. Picture of wire from Fuel pump ECM/Relay:![]()
